Question about Acer Predator G3620-UR308 - Core i7 3770 3.4 GHz : none
What happens wen rtc Batt is unloaded - Acer Predator G3620-UR308 - Core i7 3770 3.4 GHz : none
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 73 Answers
Hello. batt files or batch files are used by your operating system to run a list of commands created by ms-dos or by you. A good example of a batch file is the autoexec.bat which is loaded each time the computer boots to MS-DOS. Batch files are like shortcuts on your desktop, when they are run they pass information through the command line and these sets of instructions run commands or programs on your computer. Did that help?
Posted on Feb 09, 2014
My canon xsi about 8 months old. err 99 appear during my wedding coverage. and even i remove the cf card, the batt and change it still the err 99 appear. and wen i came home i change the lens and wen i...
err99 is a generic error code that the camera cannot identify to a particular component.
One thing to try is to switch off, remove the lens and clean the gold contacts on the camera and lens.
This is a common cause for err99 and in a lot of cases cures the problem
Jul 04, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
I do not know how to load or unload the 35 mm film.
The cartridge will only go in one way. install and pull film to marked line (should have a few notches in the film strip past gear) close camera and either wind until it stops or if batt powered it will load itself then ready to roll
May 23, 2009 | Photography
I need to reset the system password on a HP NC 4010 notebook
If it is a bios password, you can reset by using the jumper which should be located near the cmos battery.
Mar 16, 2009 | HP Compaq nc4010 Notebook
Samsung ht-ds610 wont work at all
Loading mechanism is stuck some where in loading or unloading process.
Unplug unit form AC outlet for couple of minutes and replug back in, power up and check.
Feb 11, 2009 | Samsung HT-DS610 System
Elecric start problem- kick start good
hi m8,, first try this, take the handle bar start button switch gear appart,,and clean the starter button terminals that connect wen u push button in,,spray some wd40 inside the switch gear wen u put it back together,,,,,often after off roading ,,connections that the eye cant see corrode wen the bike is washed down,, any probs still ,, shout and il anserw m8,,,,,cheers
Jan 08, 2009 | 2004 Yamaha WR 450 F
Download
Sounds like you need to replace the CMOS battery on the motherboard. It will be a round silver disc about the size of a nickel.
rtc-real time clock
Aug 02, 2008 | Computers & Internet
Aspire 5630 system time not update automatically
Hi since you have disassembled can you look carefully around the battery for any burnt components under a magnifying glass . An RTC Batt., voltage of 3.10 volts is good enough . Also look for a small crystal around the RTC section if this is not soldered properly then the real time clock will not work.
May 07, 2008 | Acer Aspire 5630 Notebook
Acer Predator G3620-UR308 - Core i7 3770 3.4 GHz : none Logo
149 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
