Seemed to leak from bottom front, but when i added water without clothes in it all leaked out but does fill from the top properly
So you are saying it leaks from the front ?? It would seem that the door gasket has a hole in it or the outlet hose has split. Take a torch and look at the bottom folds of the door gasket to see if there is a split in it. Switch off the power first!!!!then If not there bring the machine forward, tip it back against the wall (Put something underneath it in case it falls on you ) and use you torch to see where the water is coming from
