Question about LG Flatron L1515S 15" LCD Monitor
No display, power indicator off - LG Flatron L1515S 15" LCD Monitor
No display
The following applies to Acer Laptops...
If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
If pressing any key does not turn the display back on, check the following....
1. The brightness level might be too low. Press Fn and the right cursor key to increase brightness level
2. Display device might be set to an external monitor. Press Fn and F5 to toggle to the internal display
3. Backlight might be turned off. Press Fn and F6 to turn on the backlight.
4. If the Sleep indicator is lit, the computer is in Sleep mode. Press & release power button to resume.
May 09, 2011 | Acer Aspire One PC Notebook
Someone borrowed my computer and it came back with a black screen. It powers on but nothing else. Can you suggest what to try?
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 22, 2010 | Compaq Presario CQ60-220US PC Laptop
I have an acer laptop. aspire one ZG5 if i swicth it on, power indicator is on but no display
Aug 22, 2010 | Acer Aspire One Netbook 8.9" Notebook
At start up screen stays blank. Model 3422.
Aug 21, 2010 | Gateway MT3422 RTL Notebook
Wen i conect my compuer only de power light comes on.day before i working normal and i switch off normal.
Aug 21, 2010 | Toshiba Satellite 1805-S204 Notebook
On my Compaq Presario 2100US my screen has started going black intermittently while running. I then have to power it down using the power button because I can't see the screen to shut it down properly. ...
  1. Remove the battery & switch on the PC in AC mode.
  2. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  3. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
  4. If still no display, connect an external monitor, check if display is comming.
  5. If Display is coming then your LCD need to replace.
Aug 20, 2010 | HP Compaq Presario 2100US Notebook
My computer screen has been getting erratic and today it has gone blank after I power on!
Aug 20, 2010 | Lenovo ThinkPad T61 Notebook
Have laptop Compac Prosario700 it powers up but doesnt boot from drive or posibly monitor problem? black streen dosnt power downunless removal of battery
Aug 20, 2010 | Compaq Computers & Internet
I start the computer goes through normal set-up, but screen is black
Check your power cord & adapter. If its working then check the battery, reseat the battery & check. If available then check with another battery If no, then remove the battery & switch on the PC in AC mode. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall. If still no display, connect an external monitor, check if display is comming. If Display is coming then your LCD need to replace.
Aug 19, 2010 | Fujitsu Siemens LifeBook E4010 Notebook
LG Flatron L1515S 15" LCD Monitor Logo
20 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
