Log in from new compeuter - Computers & Internet
They can not open
you need to format for exfat so windows and mac can read, if its formatted as fat 32 a mac cannot read, which type of computer are you running and have you tried it in two different computers?
Mar 26, 2014 | Kingston DataTraveler 310 DT310/256GB...
How can i disable keyboard shortcut on my acer aspire 5732z
I think: configuration; file-options and restore to normal. Or look for the auto-fill and auto-content and shut off.
Feb 23, 2014 | Acer Computers & Internet
No boot and after test scaning i got error 2000-0146 hard driver
Hard Driver or Hard Drive?
If your hard drive is failing then you will have to replace it.
Apr 25, 2012 | Dell Inspiron 530s Desktop Computer
When open the compeuter must press f2 for work my computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
if this fails to fix the problem you might try safe mode
During the boot process tap the f8 button three times this will boot into safe mode where the only things
working will be your mouse and keyboard enabling you to attempt to repair your computer
is this the only key you have to press might be a log in requirement you have enabled
depending on your operating system click start control panel user accounts change the way you log on you should see log on options change the way users log on/off
learn more about user accounts increase log on security
hope this helps
Aug 24, 2011 | ASUS P5RD1-VM Motherboard
Need instructions to upload videos from camcorder
first you should what the data is being stored on .if its an sd card there may be a slot for it on the tv or you could by a conecter for sds if the tv has a usb slot.there may be a usb conecter from the camcorder to the tv or compeuter from wicth you cold get it onto the tv.
Jul 19, 2011 | Televison & Video
Dowenlood for me fax 5610 to conntact whith me compeuter
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=441125&
You will find it here.
Mar 20, 2011 | HP Officejet 5610 All-In-One InkJet...
The file is not fond my compeuter and the play no sound muisc and viduo
your operating system may be corrupted by a virus..try system restore..
Feb 18, 2011 | Computers & Internet
Sansa e250 has Refresh Database Frozen
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Please RATE my solution at the bottom.
Nov 23, 2007 | SanDisk Sansa e250 MP3 Player
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
