Question about Yamata FY811 Mechanical Sewing Machine
Bobben timing how do i set the timing
    Champion:
  • 276 Answers
With needle in centre stitch position remove bobbin cover needle plate and bobbin assy .turn hand wheel towards you until needle at lowest position, watch the rotating hook, as you turn hand wheel slowly to raise the needle 3/16" the hook should be exactly behind the needle and be just above the eye
Posted on Feb 20, 2014
Needle does not pick up the bobben
Be sure you are using a brand new needle. A bent, damaged needle sometimes will not pick up the bobbin thread. Other than that, your machine's timing is probably off. Search for sewing machine timing or take it for service.
Apr 12, 2017 | Sewing Machines
Workn maneul to fic threat go around bobbenholder en snap thread
Could be the needle/hook are out of time. May want to take it for service.
Jun 01, 2016 | Sewing Machines
How to wind the bobbin on a pfaff 1475cd
here is a link for a manual--it should have the information in it that you need
Pfaff 1475 Creative CD Instruction Manual
Dec 17, 2014 | PfaFF Sewing Machines
Empisal dressmaker 270D - top thread wont catch bobbin thread
Thanks for the advise, but I've opened the magine and it looks like at the back of the bobben, the part that controls the bobben has missed or skipped a louver so that's why my magine does not grab the cotton. The bobben case is not rotating the way it suppose to.
Jun 04, 2014 | Sewing Machines
The bobben is put in right and threaded right but the sewing isnt going into the cloth
try a new needle
try cleaning under the needle plate and in the feed dog area
it's also possible that the sewing machine needs to be checked for a timing issue.
Sep 05, 2013 | Sewing Machines
The bobben is not catching when i lower the needle down
Check to see that you have the right size needle in the machine. Rethread the machine, both top and bottom. If that doesn't help you may have a timing issue.
Apr 21, 2011 | Sewing Machines
I have an old Singer sewing machine. Probably dates around the 1950's. The machine is in a cabinet and you have to tilt it to put it away. The bobben is underneath and you have to tilt the machine to...
I tried looking up your machine by google, and what I think is yours is a Singer 319w. If, I am right, you can get a manual for it at www.sewingmanuals.com and download one for $10. They show a picture of it, and if it matches you will be in luck. If, that is not your machine, call Singer at 1-800-4singer and you can get a manual for it from them, usually $15. plus s/h. You can get parts for it at www.sewingpartsonline.com also. Good luck & have fun
Dec 27, 2010 | Singer Sewing Machines
How do you thread the bottom bobbin?
Depends, it is a top load bobbon or does the bobbon go below the needle shaft. ???
Just remember that when you place the bobbon into the shuttle the tread always has to pull clockwise. So if you are holding the bobbon facing you the thread comes from the top to the right.
Lay the bobben into the shuttle making sure you pull the threads in a clock wise motion until you pull it under a metal point that looks like a flattened needle. This is also your bobben tension and then take your hand and turn the clutch wheel slowly. You will see the thread loop around the bobben thread and pull it up.
Dec 20, 2010 | Singer Sewing Machines
Thread and bobben pattern for juki ddl 5550 machine keeps cutting bobben thread
Your bobbin case may be too tight. Try loosing it by turning the small screw a little turn to the left. If thats not it, you could also have a bend or snag in the bobbin case that is snapping the thread. If this is the case you will need to replace it.
Jun 21, 2009 | Juki Sewing Machines
I don't not have the Instructions on how the bobben should be threaded in the bottom of my sewing machine. I have tried everything that i can think of but it well not thread. If it dose come up it dose not...
The manual for this sewing machine (Model 4562) is available and may be downloaded at no cost from Singer.  The Link to that page is: http://www.singerco.com/accessories/manuals.html
Inserting a wound bobbin is found on page 15.
Aug 09, 2008 | Singer 7462 Mechanical Sewing Machine
Yamata FY811 Mechanical Sewing Machine Logo
57 people viewed this question
Top Yamata Sewing Machines Experts
Lyle Siemens
Lyle Siemens
isaac johny
isaac johny
Michael Kovalik III
Michael Kovalik III
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
