Question about BenQ E2200HD 21 inch LCD Monitor
BenQ E2200HD 21 inch LCD Monitor, remove base related issues. Get free help, solutions ... 2nd remove the 5 screws in the back cover. 3rd push and pry at the ...
Mark_Webber
  • 472 Answers
SOURCE: BENQ MONITOR
I will assume the line goes from top to bottom and is straight.
If so bad news I am affraid. It is the driver tabs that go from the panel to the physical panel controller board and is not making correct contact.
This will normally continue to get worse until you lose entire bands of the screen.
Sorry for the nad news.
Posted on Apr 09, 2008
italocub
  • 11 Answers
SOURCE: How do I remove the back of a Benq Q7T3 monitor
usually the back of some monitos come togerther by preassures clips , you can use an screwdriver (flat) or there is a plastic tools that looks like the tool that you used for remove old paint from the walls , so them stick the tools between the plastics cover and with caution force to open a litter bit at the time , possible you will brocke some of this clips but that happen all the time , best regards italocub
Posted on Jun 12, 2009
ag66339
  • 127 Answers
SOURCE: BenQ E2200HD monitor won't output sound
You do not have the necessary drivers installed. Go to the manufacturers website and download and install the recommended drivers.
Posted on Sep 22, 2009
SOURCE: Hi, my BenQ FP72G 17 inch LCD Monitor keeps
Make sure the cables are in well with a good amount of slack, it can cause a problem if your power cable or computer to monitor cable is loose
Posted on Jun 30, 2010
bruce_sharpe
SOURCE: Benq E2200HD No Cable Connected!
Just to clarify the solution posted by mnk1001: The button to press to change the input is the Enter button.
Glad there was such a simple solution to this mysterious problem! Too bad the monitor doesn't auto-detect the input.
Posted on Sep 07, 2013
Flashing
This is a very common symptom of a failure of the filter capacitors in the power supply board. The monitor is repairable, you just need to replace the 7 capacitors on the power supply board. Here is information on the board and the capacitors needed to repair it.
http://www.ccl-la.com/catalog/product_info.php?products_id=331
May 08, 2013 | BenQ E2200HD 21 inch LCD Monitor
How do I remove the back panel of the Ben Q fp222w in order to replace the power supply board. I have tried removing all the screws including the ones under the rubber grommets at the top of the rear of...
Have you been to YOUTUBE for "lcd monitor disassembly" and "lcd monitor repair" video clips??? Absolutly do not use sharp cutting instruments to part the rear cover from front BEZEL of unit. One careless slip and it's a trip to local hospital "ER" to stop the gushing wound you have inflected on your body. Good luck with repair to your unit. 12fixlouie
Sep 17, 2010 | BenQ FP222W LCD Monitor
mnk1001, Possible Failure of internal "switch-mode-power-supply"/ "CCFL inverter supply" of E2200HD. Will need to investigate to see if SMPS is in emergency shutdown mode. Please post back if you find out root cause of failure. 12fixlouie
Apr 08, 2010 | BenQ E2200HD Monitor
How do you get rid of a stuck green pixel on a benq e2200hd? ive already tried software fixes
Missing pixels are common on any LCD type of TV. The only way to get rid of it is to replace the panel itself. Do you have any kind of warranty?
Oct 24, 2009 | BenQ E2200HD Monitor
Sep 21, 2009 | BenQ E2200HD Monitor
Stem on lcd monitor can't be removed
Usually the stem has a plastic cover that hides the securing screws from view. You must pry up the cover to reveal the screws securing the stem to the monitor. This is most easily done with a Plastic pry bar or plastic putty knife. Hope this helps you with your problem.
Apr 27, 2009 | Computers & Internet
How do Iopen the case of an HPvs17x monitor?
The Capacitors on the power board are usually the reason for failure of an LCD. If you open the HP VS17 ( I can provide an exhaustive step by step If I have to) remove the five screws for the power board ( larger of the two boards) and look for an area where there are 4 caps (see pic). Look for exploded, popped up, bulging, or leaking caps and replace with the same or slightly higher tolerances. The one I replaced last night were (2x )1000uf25-50volt and (2x) 470uf25-50volt. Check the rest of the board for similar issues and replace as needed.
Jan 21, 2009 | HP Vs17 17" LCD Flat Panel Monitor
LCD Monitor
1st remove the base cover by by squeezing to release the clips and remove the 6 base mounting screws. 2nd remove the 5 screws in the back cover. 3rd push and pry at the parting line to release the clips. 4th remove the base mount by removing the two attaching screws and sliding it down about a quarter inch. 5th remove the steel cover by removing the 4 wires, two screws from power outlet, two bolts from vga plug, and the other screw in the cover. and there you have it.
Oct 26, 2008 | Acer AL1717 17" LCD Monitor
How to open casing
Just managed to open a FP17G+ monitor. My hope is that FP17G is similar and that this comes in handy.
There are 5 screws holding the casing together. Four are in the corners (black screws on my monitor). The 5th is right under the monitor stand (silver screw on my monitor.
To open the monitor, I had to:
1) Remove the monitor stand. To do so, you need to take out the two screws at the point where the base connects to the monitor (right above the pivot point) and slide out the monitor stand. THis should give you enough space to take out the 5th screw.
2) Unscrew the five remaining screws on the back of the monitor.
3) At the bottom edge of the monitor, there are two gaps between the front and back plastic panels of the monitor. You can place a wide screwdriver in this gap and gently pry apart the front and back of the monitor. Continue around the edge and the monitor will be open.
Best of luck... If you figure out what is wrong inside, let us know (I am trying to fix the same problem).
Apr 05, 2008 | BenQ FP71G 17" LCD Monitor
Power button doesn't work...
Your problem is not the switch. Probably you have faulty capacitors, deteriorated solder joints or worn out bulbs.
To open the case, remove the base (push button and lift off).
remove any screws under the base plate.
Pry the front and back cover apart, they snap together.
Good luck,
Monitor Mike
Oct 12, 2006 | Dell UltraSharp 1703FP 17" Flat Panel LCD...
BenQ E2200HD 21 inch LCD Monitor Logo
Top BenQ Computers & Internet Experts
Tony
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
