Question about Hoover Dryers
Drying cold the dryer will not heat up i have cleaned filter and condensor
IFIXALL
  • 868 Answers
SOURCE: Bosch Maxx 6 doesn't dry anymore?
Yes,it is the first thing to check ,If you can somehow see if its glowing when you start the dryer.It may also be a thermal fuse.
Posted on May 23, 2008
amgm
  • 32 Answers
SOURCE: dryer works fine but does not heat up
Hi, looks like there's 1 of 2 faults. Either the stats or the heating element. They are located at the back of the TD, covered bi a screwed panel. If you have a multimeter, turn it to buzz and check the connections. If the meter buzzes it's ok, if the meter doesn't buzz it's dead and needs replacing.
Cheers
Posted on Feb 19, 2009
  • 89 Answers
SOURCE: Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Posted on Jul 10, 2009
SOURCE: ctd40 not drying
hi have the same dryer , if you look at the back of the machine you will see a thin whiteish tube check that this in in the outlets properly
hope this helps
Posted on Aug 04, 2009
aardvarkrepr
  • 62 Answers
SOURCE: TDC32 Dryer is running but is not heating up
Hi.
Common fault with these is the two thermostats that fit on the heater at the back of the appliance -- accessable by unscrewing the back cover (MAKE SURE POWER IS DISCONNECTED FIRST!!)
There is a choice of thermostats depending on the serial number of the appliance.
If you need any other assistance please email me on: aardvark.repairs@btinternet.com
Regards
Aardvark Repairs
Posted on Nov 18, 2009
Beko condensor dryer not emmiting any heat but still 'working'
Stat or heater check power if it is a 220 volt machine may have one side down on power
Dec 03, 2013 | Zanussi TC7102W Electric Dryer
Samsung WDJ1255C washer/Dryer combo, is not drying the clothes their still warn and damp after 2x 45 min dries,The heater works, the cold valve lets water into the chamber, the fan is working, I can hear...
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.:-
Vent:------ Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.--- Heating element:----- Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it. Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.------ Cycling thermostat:------- Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.--------
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 09, 2010 | Samsung Washing Machines
Jul 10, 2009 | Amana ALE643RB Electric Dryer
Ctd40 not drying
hope this helps
Jun 20, 2009 | Hotpoint TDC32 Electric Dryer
Proline tdc6a taking 3 hours dry clothes
is it getting hot ? if not then its either the heating elements or thermostat. both available on espares. Most likely to be thermostats. If its heating then give the condensor a good clean. hope this helps.
Oct 29, 2008 | Dryers
Tricity Condenser drier
clean the condensor itself
Sep 09, 2008 | Tricity Bendix Dryers
Cdc266 tumble dryer
hi you have to clean the inside of the machine I.E. remove the drum and on the back of the machine there are two heat sensors, the ceramic sensor is possibly faulty and needs replaceing
Aug 07, 2008 | Candy CDC266 Dryer
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Dryers Logo
16 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
