Cannot get a signal into the television through the ariel or booster box
2 Suggested Answers
SOURCE: Problemw with digital TV signal using an arieal
I recently purchased an ilo 32 inch tv and am having problems because when I first purchased it I had it connected to a cable box now I no longer have the cable box just the cable and am unable to hook it up because the connecter does not hook up to a regular cable cord is there a special connection that hooks it up directly to the cable cord? I read in the manual something about a F-type connector where can I get one?
Posted on Mar 28, 2008
THIS PROBLEM IS NOT LOGICAL-SIGNAL STRENGHTS HAVE BEEN CHECKED AND WAS OK BUT THE PICTUE KEEPS BREAKING DIFFERENT ON 3 DIFERENT TVS IN THE HOUSE BUT WHEN I REMOVE ANY ONE OF THEM AND CONNECR IT INTO O
In fringe areas; where signal strength is too weak, this should happen. It sounds that, you're using an Ariel booster along with a splitter. Just connect one TV at a time, without using the splitter. If picture break occurs even this time, adjust the the signal strength of the booster [either low or high], and check whether it can help you. Keep in mind, iv the signal strength is too low, or set to too high, this fault will happen, as AGC [automatic Gain Control] circuit inside the set won't function properly. Gopakumar Gopalan Google
Dec 15, 2014 | Toshiba Televison & Video
Were is the Ariel output
You have bought a monitor NOT a tv. You need to buy/obtain a separate tuner box for tv signals then connect your tuner box to your monitor.
May 10, 2014 | Hitachi 55PMA550 55 in. HD-Ready Plasma...
My signal goes off every time the sun comes outtv no signal
On-Air RF signal strength is too low at your area. Try using a signal booster. Gopakumar Gopalan Google
Feb 27, 2014 | Televison & Video
Sony V lcd 32 inch losing digital channels and after doing a resetting scan it is ok for about 30 mins.... then screen image breaks up totally and message 'weak signal' shows on screen. Help,please.
You answered the question in your question.
''weak signal' means exactly that, however it can also mean the signal is too strong.
If you have a booster installed into the ariel remove it, if not, try one. Make sure the TV is directly connected to the ariel, not via a DVD recorder or any other devices which require an ariel input.
Sony tv's have very sensitive tuners installed so its just a case of making your aprticualr settings compatible.
Check signal strength over at www.digitaluk.co.uk
Thanks
Nov 29, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Technika 19in f/s telly in bedroom cannot get any stations with a portable ariel - can I get a different aerial instead of having to rewire the house!
One solution is to buy an hight gain aerial and a UHF amplifier booster box..but if you dont even receive poor quality signals then i think you will be struggling without relocating aerial into the loft or outside on a wal or roof. or wiring to a main aerial input via a matched splitter
Oct 17, 2009 | Televison & Video
I have installed a digital ariel but am unable to get any channels. Keep getting message no signal. The ariel works with other tv in house
You may need a digital booster when sharing 1 aerial.
They are quite cheap (£5 on e-bay is the cheapest I've seen) and easy to fit.
Also the coaxial cable can make a differance, you really need shielded and with as few joints as possible.
I hope this helps.
P.S. try tuning with just the problem set connected to the aerial direct.
Aug 24, 2009 | Televison & Video
Recieving no digital channels in my LCD TV
hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
Feb 05, 2009 | Toshiba Regza 42C3030DB 42 in. LCD TV
Cannot get a singnal on either of my freeview top sets. both are durabrand,checked with other free view users theirs is working fine
this could be your signal usually a good ariel signal booster (make sure it freeview compatable) will sort the problem
Nov 29, 2008 | Televison & Video
Mar 28, 2008 | Televison & Video
LE32R74BDX
this is because most new lcd tv's have a poor tuner built in and require a stronger ariel, to pull in the analogue or digital signal. Check that your ariel is freeview capable whether using freview or not, as these ariels are better at pulling in the signal, or do what i have had to do and buy a mains plug in signal booster from Asda for about £6.00, this did the trick, especially if you don't want to replace an ariel costing about £30.00
Jun 13, 2007 | Samsung LN-R409D 40 in. LCD Television
 Grubhead
Grubhead
