HAIER LCD 32C300 INVERTER AMP4015 SHORT - Televison & Video
Haier Model HLH326BB LCD TV. When I turn it on, the screen comes on for a split second and then goes black, but the audio is fine??
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
http://electro-medical.blogspot.com/
Dec 01, 2016 | Haier HLH326BB 32 in. LCD HDTV
My Haier tv is taking about 20 minutes for the picture to come on after I turn power on
Sep 03, 2016 | Haier L32B1120 32 LCD TV
I have a haier TV. Hooked up cable up to it and did a channel scan, I have audio but no picture. Screen just stays blue.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
May 18, 2015 | Haier Televison & Video
MY TV NAME HAIER MODEL TRINTRON , I HAVE NO PICTURE ONLY SOUND IS THERE , PLEASE SOLUTION, SOUND & PICTURE BOTH FACILITY.
Back - light problem.Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel.If so, they can't be replaced.In this case; a panel replacement is the only repair.For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS].To such sets, the power supply section circuit too should be troubles hooted.Contact any service technician.The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts.It will make surf easy.
Mar 02, 2015 | Haier Televison & Video
Have blank white screen when powered on, why is this happening?
Check its back-light inverter board. Replace it if found faulty. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 09, 2014 | Haier HL24XLE2 LCD TV
My Phillips 52" LCD TV won't turn on...it is just
it possibly you have shorted power supply board or inverter board that cause of clicking sounds..
try to unplug the inverter board then try again if the indicator lit in blue you have shorted inverter board that need to be replace.
Nov 06, 2012 | Televison & Video
My tv is jumping like a stobe light
It may have power supply, T-CON board, main board, or backlight inverter problem. You need to do in-depth troubleshooting.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 14, 2010 | Haier HL32R 32 in. LCD TV
Screen went black/blank can hear sound no picture, cannot change source or access menu LN-S4692D
Your inverter circuits and/or power board need servicing.....
Either three fault scenarios are happening:
1. the inverter circuits are not producing AC ripple too the CCFL lamps that illuminate the LCD glass panel.
2. the power supply board is not feeding 24vdc - 12vdc sustain voltage too the inverter circuits. Meaning, no dc high voltage output from the power board.
3. The timing control circuit (LCD Board) has shorted switching devices or on-board memory has failed....which causes data/dc loss at the input which results in the inverters canceling load power (lamps). The sync data between inverter and LCD Board are absent. This will result in a 'NO LIGHT' condition on the LCD display.
Number 3 is a rare case, its usually #1 the inverters need servicing.....
Nov 10, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
