Question about Seiko Watches
741178 4004 parts
Missing battery cover
What battery does the Invicta 2634 take?
Take your watch To a jeweler who will open it and identify the battery type. You might even arrange to have it replaced.
Mar 24, 2017 | Invicta Watches
Removing back of irish collection ladies watch for new battery
Replace Your Watch Battery Yourself With Household Tools ...
? 7:32
https://www.youtube.com/watch?v=L4Y7pDonkmk
Aug 15, 2013 - Uploaded by tsbrownie
How to replace a watch battery yourself using common household "tools". Covers both snap back and screw ...Missing: irish
How to Change a Watch Battery with Normal Tools - YouTube
? 9:18
https://www.youtube.com/watch?v=gFmV7NIjVsw
Sep 1, 2011 - Uploaded by RichsMethods
I also show how to polish the metal portions of your watch. ... of how not to take the back off and remove ...Missing: irish
Dec 21, 2015 | DG Watches
I can't get the analog time on kennth Cole kc9110 watch after changing battery the digital part in running fine please help thank you
With this type of dual display watch, the two 'mechanisms' are often independant with their own batteries. It's quite possible that the battery for the analogue display has been missed - often they are underneath the battery for the digital display with an insulating cover to isolate the batteries from each other. Sometimes it's even necessary to remove the digital module to get to the analogue module. Obviously, you would need some experience of dismantling watches (and to be very careful) to sort this out. If you don't feel confident, and you value the watch, take it to a professional.
Jul 11, 2015 | Watches
I have a womens Columbia watch that is also water resistance to 65 meters. The battery has gone dead and I would like to replace it. Most watches have a groove to pry the cap off. This watch does not have...
mcdevito75 here, Hello Traudl, I see what you mean by not seeing or haveing that little tab on the back cover to pry off the back. I'm not an expert but do know a little about watches. Look again for this tab on the back cover, use a magnifier glass available at all Dollar stores to see this tab. Of course you may be right and there isn"t a tab, in that case look carefully between the back cover and the case of the watch for a cutout, it should be somewhere between the back cover and cvase of the watch, it"s very easy to miss this is why I suggest the magnifier glass. If by chance the back cover has square holes going around it"s circumference, then you would need a special tool to unscrew this back cover, I don"t think so though. If all this fails then your best bet is to look for a small watch repair shop in your area for a new battery. Hope I've helped.
Sep 13, 2010 | Columbia Watches
How do you open the back of the Timex Ironkids wristwatch in order to replace the battery? It has four small screws and part of the plastic wristband keeps me from prying off the back to replace the...
mcdevito75 here, Those 4 screws hold the back onto your Timex. Do not try to pry off the back cover, rather you"ll need jewlers screwdrivers to un--screw that back cover to replace the battery.
Jul 31, 2010 | Timex IRONKIDS 70491 wristwatch
My Casio watch Battery was just changed now I can
mcdevito75 here, Return to where the battery was changed, for adjustments.
Jul 12, 2010 | Casio Watches
Casio PRO TREK error 'OP EN' Display frozen with the above msg. None of the buttons - except the light - works. Whats wrong .. battery charge shows FULL
The problems is very simple: On the back cover (inside) is a little Cu metal Part. This part is glued to back cover using a poor glue (rubbered glue) and, in time, is moving from original position. You must put back this parts to original positin ( a little hole inside of back cover) and glue using a good glue. When the back cover is mounted , this part must have a ferm contact with two springs from mechanism (sensor for back cover open). If beatwin this springs isn't a electric short (using Cu metal parts) the internal mechanism of watch "see" the back cover is open and show "OPEN" on screen!
Mar 22, 2010 | Casio Watches
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
May 12, 2009 | Timex Expedition 84601 Wristwatch
Back Cover Missing
First you have to check on ebay as very many parts are sold there. Check in jewellery and watches/watch parts and tools/acsessories. It may take a while as there is no 100% guarantee.
Another way is to find out your nearest Anne Klein store, bring the watch in and ask if they can supply needed caseback. You can find it here: www.anneklein.com
And the last one is to go to your nearest watchmakers shop and ask for help. They have all connections and should be able to help.
Regards
Arthur
Dec 16, 2008 | Anne Klein 12 1821WMSB watch
Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Mar 15, 2007 | Fossil University of Oklahoma LI2282 Sport...
Watches Logo
19 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
