Question about Irons
Descale Philips instant care steam generator - Irons
2 Suggested Answers
SOURCE: how do i descale my steam generator iron
how do i descale the hinari steam generator
Posted on Mar 19, 2010
No steam coming throwc
Normally when water is put inside steam irons, it get stored in tank then if thermostat knob is set for steam then water moves to bottom heated portion of iron. Water converts to steam as base plate is hot, heated steam comes out through perforated holes. If holes are blocked due to scale formation steam flow is blocked. The descaling has to be done as per instructions given on descaling wax manufacturer. sometimes if water does not enter through a rubber washer that is water tank to heated bottom portion then also steam will not get generated hence no steam. Please check above points and identify the problem.
Jan 08, 2015 | Irons
Philips 8300 steam generator iron keeps cutting out
I have this iron about 2,5 years, work a few times. when i shut down the steam generator the iron stays on. And now in one hour of work it shuts downs about 4 times. the lights on the steam generator are week. what main board i shuld switch?
Mar 21, 2013 | Irons
How do i descale it
Fill the tank with regular malt vinegar and leave it overnight, Was out in the morning and should have removed most of the scale. Then mix two parts vinegar and one part water and fill the tank again. Heat the iron up to max setting and steam through to remove any small deposits in the steam holes. Repeat if needed.
Feb 27, 2011 | Philips HI-296 Iron
HOW DO I DESCALE A STEAM GENERATOR IRON
Place the iron soleplate, unplugged of course, in a shallow dish of water and descaler and leave it for a while. I have just done this with mine and its working a treat.
Dec 19, 2008 | Maytag MLI7500A Iron
Tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Jul 13, 2008 | Irons
Tefal Pro Express Steam Generator Iron
Once you have filled up with water and always just below full line, if your model has one, you need to press the "reset" or "restart" button on the back end of the generator (the end furthest away from the water container). Also, do be sure to regularly descale as advised above otherwise the water/steam can't get through.
Jan 21, 2008 | Irons
Irons Logo
77 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
