Question about Mastercool 67680 Evaporative Cooler Air Conditioner
Bonaire fault codes er5 - Mastercool 67680 Evaporative Cooler Air Conditioner
Fault code five on bonaire evaporative air con
To less information, minimum Modell Number needed.
Following link you'll find a manual, this can help you to fix your problem.
http://www.bonaire.com.au/lib/pdf/OM/RAC_Owners_Manual_6602201B.pdf
Oct 19, 2014 | Heating & Cooling
What does the error code ER5 for a EDW154E Eurotech D/W mean?
e5 error is drain error. need to check all drain related items.
drain pump, drain hose, and of course garbage disposal knock out.
Jun 06, 2014 | EuroTech 24 in. EDW154E Built-in...
Need a universal remote and code to replace my bonaire DS125 evaporative air conditioner remote
If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 16, 2013 | Televison & Video
Need a universal remote to replace my bonaire evaporative air conditioner remote
27,25,20,26 are the codes to check with. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Mar 09, 2013 | Logitech Televison & Video
VULCAN BONAIRE Users manual.
Try here http://www.bonaire.com.au/support/documentation/owner/default.aspx
Dec 31, 2009 | Heating & Cooling
Can't remove rear brake panel and shoes from brake drum on ER5.
if the rear shoes have jammed the way i normally fix this problem is to undo and remove the arm so you are left with the spline sticking out. then knock this in carefully and it should release the shoes and you should be able to remove the hub.
May 05, 2009 | 1997 kawasaki ER-5
My rev counter does not work on my kawasaki er5 1999
The ER5 has got an electronic rev-counter, no cable.
Like the oval rear brake-drums this is another ER5 bugbear, the rec/rec fails, the battery boils and the rev-counter is usually a victim too.
Often on ER5 specific forums there will be someone who repairs the circuit board and sells the repaired units much cheaper than a new one. it's usually a tiny zener-diode that is killed.
May 04, 2009 | 1999 kawasaki ER-5
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
102 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
