Home | HP | OfficeJet k60 All-In-One InkJet Printer | I have a HP Off...
HP OfficeJet k60 All-In-One InkJet Printer
Problem for HP OfficeJet k60 All-In-One InkJet Printer
I have a HP OfficeJet K60 printer. I have a
By jdrose on Jun 07, 2009
I have a HP OfficeJet K60 printer. I have a Linksys WRT54G V8 broadband router. I would like to set up printer so that I can print from my laptop without connecting the print cable to the laptop.
Solution #1
posted on Jun 07, 2009
Not Rated)
Yvonne A
Rank: Wiz
Rating: 84%, 82 votes
Do you have the jetdirect print server attached to the printer? If so, follow the instructions for the print server setup before connecting to the broadband router
Was this helpful?
Yes
No
Popular Solutions for HP OfficeJet k60 All-In-One
Questions and Unsolved Problems for HP OfficeJet k60 All-In-One
Do you recommend HP OfficeJet k60 All-In-One InkJet Printer?
Answer
Answer
k60 is on home network. Print jobs stay in que and will not print. Was working fine ubtil a couple... (More)
Answer
hp k-60 scanner failure (does not work when turned off and on) I need to use fax - will not fax has... (More)
Answer
How do I scan a document? I am getting a message that indicates that the options are not set.
Answer
With my K60 HP printer I want the option to print only in balck and white to conserve the color ink.... (More)
Answer
Opened printer - pieces of paper stuck in roller in back - can't seem to open
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP OfficeJet k60 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 437
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
