Question about Scosche Industries Car Audio & Video
Remote manual keyless - Scosche Industries Car Audio & Video
Cant open up car with keyless remote
reprogram ur remotes as per owners manual
Feb 24, 2014 | 2000 Volkswagen Beetle
How do you prgram remote keyless entry
Here are the instructions from the factory service manual:
1. Enter 5-digit permanent entry code into the keyless entry keypad.
2. Within 5 seconds of pressing last button of code, press the 1/2 button. All doors will lock then
unlock confirming you are in programming mode.
3. Press any button on first Keyless Remote within 5 seconds of pressing the 1/2 button. Locks will
cycle to indicate succesful programming.
4. If you are programming more than one Keyless Remote (Including any exsiting remotes) Press
any button on second keyless remote within 5 seconds of previous remote. Locks will cycle again
to indicate succesfull programming. (If the keypad light goes out before all remotes are
programmed the entire process must be repeated).
5. Press the 7/8 and the 9/0 buttons simultaneously on the keypad to exit program mode.
Sep 14, 2011 | 1995 Ford Crown Victoria
Program factory remote keyless entry for 2003 Hyundai XG350
This bulletin supersedes TSB# 02-90-001.
DESCRIPTION: The security system keyless adapter cable (SPX/Kent-Moore P/N 09900-21300) is a special service tool (SST) that is used for programming new keyless entry remote transmitters to the factory security systems. The keyless adapter is used in conjunction with the Hi-Scan Pro (with Hi-Scan SOL Pro Software Version 09-29-03
or newer) and Data Link Connector (DLC) Cable. SERVICE INFORMATION: The keyless adapter cable can be used on the following vehicles:
  • 2001 - 2004 MY Elantra
  • 2001 - 2004 MY Santa Fe
  • 2002 - 2004 MY Sonata
  • 2001 - 2004 MY XG300/350 0390020a.gif
NOTE
  • The 2003 - 2004 MY Tiburon does not need the Keyless Adapter Cable to add keyless entry remotes to the factory security system. Instead, the Hi-Scan Pro connects to the vehicle using only the DLC cable. See page BE-60 in the 2004 MY Tiburon Shop Manual for the latest instructions.
  • The most current Keyless Adapter Cable Instructions are available in the following shop manuals:
SHOP MANUAL
PAGES
2004 MY Elantra
BE-73 - BE-74
2004 MY Santa Fe
BE-43 - BE-44
2004 MY Sonata
BE-40 - BE-41
2004 MY XG350
BE-46 - BE-47
KEYLESS ADAPTER CABLE INSTRUCTIONS:
  1. Connect the keyless adapter cable to the Hi-Scan Pro DLC cable. 0390020b.gif
  2. Plug the keyless adapter into the vehicle's 10-pin multi-purpose connector located behind the driver's side lower instrument panel (next to the DLC). NOTE Sample vehicle shown is the Santa Fe.
  3. Turn the Hi-Scan Pro ON
    and press ENTER
    . NOTE "Release date 29. Sep. 2003" OR LATER
    must appear on this screen. To update your SOL card with the latest software go to www.hmaservice.com and refer to TSB 00-00-001.
  4. Select option "HYUNDAI VEHICLE DIAGNOSIS"
    and press ENTER
  5. Select vehicle model and press ENTER
  6. Select option "TRANSMITTER CODE SAVING"
    and press ENTER
  7. Ensure that the key has been removed from the ignition cylinder before proceeding. 0390020h.gif
  8. Follow the steps noted on the Hi-Scan Pro screen to program the remote(s). NOTE The factory security system can only be programmed to accept two remote transmitters and MUST be programmed for both remote transmitters at the same time.
  9. Press ESC
    on the Hi-Scan Pro and verify that the remote(s) are functioning properly.
  10. Turn the Hi-Scan Pro OFF
    and disconnect the adapter cable from the multi-purpose connector.
May 22, 2009 | Hyundai Motor 2003 XG350
How do I tell if my used car had a keyless remote
it would be quit a job to set your car up with a keyless remote.unless you found some one very very very good whit wire.but to tell you the truth i do not thik it hwate of time . it would cst a hole lot of money .hope i help you
Apr 09, 2009 | 1999 Honda Civic
Remote programming
http://www.caralarm.com/manuals/MARS/MARS-22.pdf
The above web address will give you the information you are looking for.
Mar 31, 2009 | Omega MARS-22 Remote Vehicle Starter with...
2006 chevy equinox keyless remote programming
from the service manual:
There is no onboard programming procedure for this vehicle. This vehicle requires special equipment be connected to the vehicle to program the keyless remote. Please go to the nearest GM dealer for assistance
Mar 26, 2009 | 2005 Chevrolet Equinox
My remote for the keyless entry does not work.
does trunk button work? panic button?
here's 2003 info:
  • The doors do not lock/unlock using the remote transmitter
  • Remote transmitter.
  • Driver door module (DDM).
  • Go To Pinpoint Test G .
SECTION 501-14: Handles, Locks, Latches and Entry Systems 2003 Town Car Workshop Manual
GENERAL PROCEDURES Remote Transmitter Programming
  1. Cycle the ignition from OFF to RUN four times within three seconds. The locks will then lock and unlock, confirming that the program mode has been entered.
  1. NOTE: When the first keyless entry remote transmitter is programmed, all other keyless entry remote transmitters are erased.
    Press any button on the transmitter to be programmed.
  1. If additional keyless entry remote transmitters are to be programmed, repeat Step 2 within 7.5 seconds.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
report back
Mar 22, 2009 | 2004 Lincoln LS
Car Audio & Video Logo
12 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
ravie__s
Level 1 Expert
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
