Question about Home Security
I need a replacement bell push for seimens jsjs217
The door bell push has brocken
Diagram for connecting a battery operated door chime to push button
IF you are going all elec,you need a door bell,bell transformer and of course the push button. This is all low voltage so phone wire will work.You are just using 1 pair of wires so pick a pair such as the blue pair.Wire from push button to transformer to door bell.It is not polarity senstive....simple to do
Mar 17, 2015 | Cars & Trucks
I replaced old DH840E that stoped working with same model same hook up with front door only. When I push door bell it dongs once only. If I hold door bell button it goes through the west minister chime....
Some door chimes of this type are designed with dual capability so that pressing the front door button produces the full Westminster chime and pressing the back door button produces a single chime. Your wiring may have gotten reversed inadvertently during the changeover
Aug 17, 2013 | Robert Thomas Carlon Recordachime By...
Siemens jsjs-208 door bell
Mine keeps doing it. Taking a battery out to force reset on the ringer but mine seems to need this every few weeks. Tried new batteries but still problems.
Mar 19, 2013 | Bell Sports Wireless Door Bell with...
Flashing signal saying door
Door is only closed on first Latch, Push door more forcefull, could also be brocken Latch or Micro schwitch
Jan 22, 2013 | Washing Machines
I have a Siemens Wireless Doorbell (Model No. JSJS-204. It started making ringing tones when no one was pushing the doorbell. I replaced the battery thinking that it was wearing out. Now the unit does not...
Hi
To fix the issue you need to remove the batterys from both the bell push and the bell unit for 10 mins, then replace the batterys and then push the bell push so it can switch channels and be different from the house down the road
Sep 17, 2011 | Vacuums
I have a desa DD100S wireless door chime but for some unknown reason the bell push is not working, I have tried replacing the battery but still unable to ring chime. The actual base unit is fine and...
Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
Mar 09, 2011 | Desa International White Wireless Plug In...
Button Press (Not Remote) Normal Door Bell Makes Slight Buzz Only
The electromagnet that causes the bell clapper to move when the circuit is closed by pushing the button is failing. Replace the bell unit.
Jul 07, 2009 | Desa International White Wireless Plug In...
Home Security Logo
78 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
