Question about Netopia 3-D Reach (TER/GUSB-N1) (TERGUSBN1) 802.11g/b Wireless Adapter
Connect wireless card wifi - Netopia 3-D Reach (TER/GUSB-N1) (TERGUSBN1) 802.11g/b Wireless Adapter
I can't figure out how to connect to the internet with my Belkin card.
this is wireless (wifi) receiver
the first you need is wifi connection around your computer
if there any wifi connection aroud you, at your computer open and search the available wifi connection, then chose connect
and you can connect internet after you connect your belkin to wireless connection
Mar 25, 2011 | Belkin (F5D7011) 802.11g/b Wireless...
Tip
How to Connect a Laptop to a Wireless Router
  • 1 Purchase a wireless router that fits your needs and price range.
  • Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • Click on "Properties."
  • Select the "Wireless Networks" tab.
  • Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Avable Networks" section.
  • Click on "Configure" when you see your network's SSID in the "Available Networks."
  • Enter your network's SSID and WEP key.
  • Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • on Oct 08, 2010 | Computers & Internet
    How to connect new laptop to router
    Hello
    Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
    Hope it helps, if so do rate the solution
    Good luck
    Dec 24, 2010 | Linksys Wireless-G WRT54G Router
    Please what is Wifi and where can i find the button to turn it on or off.
    WiFi is a wireless connection, if you have a wireless router and it is connected to the Internet, then you can connect to the Internet using the wireless card in your D600.
    If you don't have a wireless router, then you can connect to the Internet at a free WiFi hot spot at locations such McDonalds, Starbucks and the airport.
    This model D600 may not have a wireless card installed.
    If it has it will be an Intel {ro wireless card. Check the Device Manager - Network Adapters, if you do not see a wireless adapter then you do not have a wireless card installed.
    If you have a wireless card and the wireless driver is installed the you are ready for wireless connection. There is no button to turn on the wireless card, it will be ready to use.
    If you require information on setting up your own wireless network, please click on this link and follow my instructions :-
    Normal 0 http://www.fixya.com/support/r3559128-wireless_router_security
    Oct 09, 2010 | Dell Latitude D600 Notebook
    How to install my router for wireless internet on my laptop.
    1. Purchase a wireless router that fits your needs and price range.
    2. Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
    3. Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
    4. Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
    5. Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
    6. Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
    7. Click on "Properties."
    8. Select the "Wireless Networks" tab.
    9. Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
    10. Click on "Configure" when you see your network's SSID in the "Available Networks."
    11. Enter your network's SSID and WEP key.
    12. Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
    Thanks.
    Have great day.
    Oct 01, 2010 | Computers & Internet
    I dont know to use wifi in LENOVO 3000 Y410
    Hi. First things is you should have a wireless router there or you are at a certain hotspot where there is a free wireless internet access e.g Starbucks. Procedure below:
  • 2 Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • 3 Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • 4 Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • 5 Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • 6 Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • 7 Click on "Properties."
  • 8 Select the "Wireless Networks" tab.
  • 9 Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
  • 10 Click on "Configure" when you see your network's SSID in the "Available Networks."
  • 11 Enter your network's SSID and WEP key.
  • 12 Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • Sep 05, 2010 | Lenovo 3000 Y410 Laptop
    I dont know how to connect it to my laptop wireless
    Aug 01, 2010 | Computers & Internet
    Boost PCMCIA Wifi Card Range
    em maybe you just need to change the pc card or honestly just change the pc for fast and efficient browsing.
    Jan 21, 2009 | Encore IEEE 802.11b WiFi Wireless LAN...
    I want to connect to my wireless Internet connection
    If everything is working as it should. All you have to do is turn onyour Wi-Fi. You will then see a popup asking you if you would like toconnect.
    You may need to add a compact flash wireless card:
    • http://wifi.aximsite.com/wifi-faq.html#_51-card
    • http://www.amazon.com/SPECTEC-Wireless-Networking-Connection-Notebooks/dp/B000BD9PBQ
    You'll find a comprehensive axim wifi guide here: http://wifi.aximsite.com/
    Oct 28, 2008 | Dell Axim X30 Pocket PC
    No wifi
    The Fujitsu Lifebook S5582 does not have an integrated Wireless network card. This laptop was manufactured in 2001-2002. The integrated Wifi card was not generaly common in laptop computers until 2004.
    So, you will need to buy a wireless adapter if you want to have wifi connectivity. Since this laptop is quite old, I would recommend a PCMCIA (a.k.a. PC card) adapter instead of a USB because it will be much lighter on the processor load.
    You also have to be aware that using a wireless card will use more battery power and therefore shorten the expected autonomy of the laptop when running on battery.
    Feb 17, 2008 | Computers & Internet
    Netopia 3-D Reach  (TER/GUSB-N1) (TERGUSBN1) 802.11g/b Wireless Adapter Logo
    35 people viewed this question
    Top Netopia Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
