Bosch maxx WFO 2820
The water is not coming to the machine
  • 139 Answers
SOURCE: Bosch Maxx WFL 2260
Hey check to see if you can move the drum by hand,, if you cant the the bearings on the drum have gone and it is seized ..
If you can turn it by hand then most likely it is the carbon brushes on the motor..
hope this helps
any questions dont hesitate to contact me im here to help....
Posted on Jan 17, 2008
  • 1527 Answers
SOURCE: bosch maxx wfl 1300 washing machine that wont start.
hello could be brushes on the motor. there are 2 black clips that sit on the motor after time these whare down just slide them out and slide new ones in good luck
shaun
Posted on Jul 21, 2009
beltronic205
  • 1474 Answers
SOURCE: Bosch Maxx - softener not dispensing into machine
It blocks very often , give it a good clean..remove soap dispenser to do so
Posted on Sep 28, 2009
tony2155
  • 64 Answers
SOURCE: washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
Posted on Mar 28, 2010
SOURCE: Bosch Maxx 5 Washing machine will not wash, drum does not spin.
maxx5, error F63
Posted on Dec 14, 2010
Bosch maxx WFO 2050 will not spin how do i fix it
Post the make and problem on youtube they will have similar
machines with this problem.
Jun 19, 2014 | Bosch Washing Machines
How is reset bosh wfo2062
How l reset busch maxx 6062 wfo
Mar 07, 2014 | Bosch Nexxt 300 Series WFMC2201UC
BOSCH MAXX WFO 2062
Have you checked the outlet pipe that the machines pipe discharges into ? Sometimes these get filled up with sludge etc and may siphon back in smelly water at the end of a cycle. You could also see where the pipe drains into the sewer system , see if there is a local blockage.
Jan 08, 2014 | Washing Machines
My Bosch Maxx 2000 WFO 2060 is leaking from the bottom. Could it be that a filter somewhere needs to be cleaned? If so where is the filter located?
The filter is usually located at the bottom right front of washer, sometimes behind a removeable cover, or a drop down flap.If you can locate it, then unscrew it anti-clockwise to remove and clean it.
There is also a possibility that there could be a hole or tear in the door seal so check the seal as well.
Hope this is of some help to you .
Dec 07, 2009 | Bosch Washing Machines
How to disable beeps in Bosch wfo 2442 oe
please tell me somebody how to turn off spin for bosch WFO 2442?
May 29, 2009 | Bosch Washing Machines
Bosch Maxx WFL 2060
connect at random. put on a rinse cycle. if cold water comes in then pipes are correct. if hot water comes in then pipes are wrong way round and just swap them
Sep 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Water level sensor faulty
needs must.........you will need to remove lid........look for thin plastic tube coming from bottom of the drum to the top of the drom......connecting on a small plastic unit......this is the pressure sensor.....remove the tube.......blow down it a few times.............might be blocked by grit etc........
cheers
May 27, 2017 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
