Question about Vehicle Parts & Accessories
Codes to program garage door opener for 2001 passat
Doorguy27
  • 30 Answers
SOURCE: program my garage door opener
What the last guy post is correct, but you have to tel your car what kinda remote you have. Assuming you have homelink Which 95 percent of the cars do ill give you a very short version on how to do this. First thing you need to do is clear the code in your car from any other owners. Do do this turn your car's key to the on or acc non running position. Press and hold the first and last button. Untill the light reacts different ether starts flashing or flashes faster etc. Then you need to get one of your remotes. Press and hold the button you want to set in your car and press your remote button at the same time untill the light reacts diferent. Mind you hold your garage remote as close to your car remote as you can. Then finally Find your learn button on your garage door opener it's self it can be in the back or the front if its in the front you have to remove the cover press the button once DO NOT HOLD IT. then go to your car and press the button you set for about 2 seconds and repet 1-2 more times untill your garage door moves. Make sure nothing is in the way of the garage door. (I know that should go with out saying.)
Posted on Feb 10, 2009
  • 1348 Answers
SOURCE: programming garage door opener
there are three buttons on the opener.hold the 2 outside ones down for 25 to 30 seconds to erase the program. once the light (if equipped)flash rate changes,let go.
then push any one of the the three buttons and hold it in. and then push your remote. when the flash rate changes,the code is now in the homelink transmitter.the slt and slt plus had that feature.
Posted on May 14, 2009
turo1000
  • 18 Answers
SOURCE: program instruction garage door opener in 2005 chrysler pacifica
if your garage motor have rolling codes you need to put your car inside garage near the motor leave ignition on go to the motor locate learn button press it then quickly go to the car and press and hold one of the buttons for approximately 30 sec or until it start blinking rapidly, if you have a regular motor take one hand held opener go inside car ignition on same time press open button on handheld remote and on the car button 30 sec and it should be programmed.
Posted on May 18, 2009
  • 150 Answers
SOURCE: In following the Chevrolet Tahoe instruction to program a garage door opener, I am having problems with the system working. The codes are the rolling key type.
Press the outer 2 buttons untill the bink rate changes then release.
Press the button you want to train at the same time you hold down an unused button on one of your factory GDO remotes, hold untill flash rate changes.
Press learn button on GDO, press the button you just programmed in the Tahoe, should be programmed.
(Info should be in users manual under HomeLink.)
Posted on Aug 07, 2009
SOURCE: programming the garage door opener
Homelink Garage Door Opener Programming Procedure:
The procedure described below was successfully applied to a 2005 Jaguar S-Type.
To begin with, several attempts were made using the programming instructions contained in my Jaguars owners manual. Though the procedure described in the owners manual was straight-forward and understandable, I was unsuccessful in getting the vehicles remote to make my garage door opener function. The particular garage door openers I have are both made by Genie. Both openers utilize the Rolling Code feature.
To begin with, be sure to clear previous codes on your Jaguars garage door opener by first turning (rotating) the ignition key to the I position (first notch). Next, simultaneously hold button 1 (left most button) and button 3 (right most button) down until the middle buttons red light changes from continuous on to a rapid flash. This process takes approximately 20-25 seconds. What follows is a two part process. In the first part, get your Genie portable remote and hold it near (approximately 3 inches away from) your Jaguars garage door opener console buttons. Choose which button on your Jaguars remote you wish to dedicate to your Genie door opener and simultaneously press and hold your Genie opener button and your Jaguars opener button. The red light on your Jaguars center button (button #2) will light up and within 1-2 seconds will begin to flash rapidly. You have just completed part 1 of the two part process.
Part two: Now it is time to utilize the Learn function on your Genie garage door opener. Press the Learn button on your Genie garage door opener. The red LED adjacent to the Learn button will begin to flash. You now have 30 seconds in which to program your Jaguars opener button. Using the same button you just used in the part 1 procedure, press and hold the same button for several seconds. As before, your Jaguars red light in the middle button will light up and within 1-2 seconds, it will flash rapidly. Release the button you are programming. Now, here is the key piece of information! Once again, press and hold that same button. Once again, the center buttons red light will flash rapidly. Release your newly programmed button. This procedure proved successful in my application. Here is what has just happened. The first time you pressed your Jaguars remote button tells the Genie opener that it exists and that it is a viable candidate for making your life easier (opening the damn door). The second time you press your Jaguars remote button confirms to the Genies rolling code that your Jaguars signal is legitimate and is to be trusted from then on.
Posted on Dec 23, 2009
Garage door opens randomly
Steve, If you have a remote door opener, change the code, as one of your neighbors may have their door using same code. Also make sure there is nothing hanging or blowing in front of sensor lights.
below are links, how to.
press the helpful button
How to Program Garage Door Remote Change the Battery Craftsman 315
Garage Door Help How to Program Your Garage Door Remote Control
How to Adjust Your Garage Door Opener Travel and Force
Feb 12, 2016 | Building Materials
How do I change the code on my garage door opener. Have one and lost one.
Press an hold the learn button on the garage door opener for 10 seconds. You will notice an amber LED either next to or above the learn button. When the LED goes out the anything that was previously programed will be deleted. Now press and release the learn button once the amber LED will come on steady. Now press the button on the garage door opener you want to program to the garage door opener. You will hear a click and the light bulb on the garage door opener will go off and come back on. Your garage door opener remote is now programed with a new code.
Feb 22, 2015 | Chamberlain Televison & Video
How to program my cars garage door opener buttons for my garage door.
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
May 15, 2010 | 2001 Nissan Altima
How do i program my garage door opener with my diamante
Most garage door systems, using ROLLING CODE technology work like this: You have to be ready with someone in the car, ready to push the button.,then you press a button on the garage door unit (get a ladder, and a light, climb up and READ the directions). this button press opens INVITE to any remotes. then have the person in the car press the button.
The reason for READ on garage opener is that one botton invites, and another CLEARS all remotes.... if you press that one, all remotes need to be reinvited.
Mar 14, 2010 | 2001 Mitsubishi Diamante
Garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote entry code
This multi code device can be programmed. Make sure the battery is good. Linear.com has all the manuals and directions for coding in. make sure and get the model number of the opener and the keypad. Thanks BB
Mar 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
How can I program my 2001 volvo to my garage
The owners manual has the procedure for the programming and the number for "homelink" customer support to help with rolling code garage door openers.
http://www.volvocars.com/us/tools/OwnersInfo/Pages/VolvoOwners.aspx
The above website has an online owners manual. Just register and click on YOUR VOLVO then click on SEARCH OWNERS LIBRARY.
hope this helps.
Feb 21, 2009 | 2001 Volvo V70
Home link system will not accept garage door code.
I purchased a Chamberlain belt garage door opener. It was great! The lease on my duplex ended and the landlord bought it from me.
I found that the best way to program my vehicle's HomeLink buttons (to read the remote) was to do the learning procedure in a parking garage. This way the signal is not interrupted by all the waves around us.
Jan 02, 2009 | 2001 Lexus ES 300
Vehicle Parts & Accessories Logo
14 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
