Question about Gorenje Refrigerators
The frig has stopped working.is there a reset button for a gorenje bar frig, its about 15 years old
3 Suggested Answers
SOURCE: changed bulb in frig and light still not on
I would stick with an appliance bulb. The glass in those is more resistant to extreme temperature changes.
Your problem sounds like it could be that the door switch has burned/corroded contacts.
If you have a continuity meter you can remove the switch and test it to see if it's working.
BUT, FIRST, TURN OFF THE BREAKER TO THE FRIDGE!!!!
If you don't get continuity thru it, soak it in rubbing alcohol for about an hour. Let it dry for about an hour, and test it. If it's still not working, replace it.
If you need help with the continuity testing, let me know.
Posted on Apr 30, 2009
  • 1218 Answers
SOURCE: twice in five months on a four year old frig. The
Good day,
If it happens that infrequently then nothing is technically broken.
More of a design, engineering issue.
Check this. It's for a freezer but the rules are the same.
http://www.fixya.com/support/t4759036-upright_freezer_not_drain
Posted on May 17, 2010
Refrigerator makes a loud thud every 15 minutes
compressor has a broken spring inside. only way to fix it is replace compressor. call management.
May 07, 2017 | Refrigerators
Ice maker stopped working on bottom freezer amana. Is there a reset button?
There is n such reset button,but first check and confirm that water line is running in to the ice maker drawer.Is the water getting into icemaker or not.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Amana ARB2214C Bottom Freezer Refrigerator
Three weeks ago my refrigerator went out including the freezer. We pulled it out, used our wet/vac and cleaned it out then turned the reset button and it worked fine. A week later it went out again and we...
im not sure what reset button you are using / but cleaning it out was good . and if it started running that was good. when it quit the third time . things that would cause this could be the cold control / very common / and at 15 yr old i would replace the compressor relay . that starts it . sometime you can hear it clicking or humming . ( trying to start . . so try the relay .. . and ck for bad connections on old wires to the compressor as the get brittle and burn off .. mm hope this helps .. feed back .. pls
Jan 19, 2011 | Amana Refrigerators
There is a strong acrid odour coming from my Amana refrigerator. This frig is 15 years old and has a top freezer.
It may be a refrigerant leak in the coil and it will stop working soon. When this happens it's time for a new box. 15 years is a good run.
A new coil could cost as much as a new frig and that's without labor cost.
I hope this helps
Aug 23, 2010 | Amana Refrigerators
Temp is erratic too warm, too cold ....
Sounds like the defrost timer is not working correctly or the start capacitor is malfunctioning,Both are cheap and easy fixes.
May 09, 2009 | Refrigerators
Changed bulb in frig and light still not on. Frig is older whirlpool. est age is 15 years. i thought bulb was just burnt out. everything else still working. replaced old bulb 15 w with an "appliance" bulb...
Apr 30, 2009 | Whirlpool ET8MHK Top Freezer Refrigerator
GE Profile Refrigerator Ice/Water dispenser not working
Hi Urban Woman,
Unfortunately, your dispenser interface board has gone to appliance parts heaven and needs to be replaced. Fortunately it's relatively cheap. If I recall correctly, all you have to do to access the dispenser board is use a small flat screwdriver. There are 2 locking "tabs"/slots on either side and underneath the board (you will barely be able to see it, they're just that small). 6fb5654.jpg
Of course you already know that you need to unplug the fridge before doing any repairs so I can skip that part.
Insert your screwdriver into those slots and pry the bottom of the board out. Then grasp it with your hands and remove it completely. There are three wire bundles on it, remove them and re-install them on the new board. Then simply snap the new board into place.
This should take maybe 15 minutes to do... super easy job.
SG
p.s. Here's a link to the service manual, but the removal of the dispenser board is not in it (everything else is, though, so it may come in handy later)
p.s.s. Since you're going to be unplugging the fridge for the repair, you ought to go to Home Depot and pick up one of these to plug it back into. Transient voltage spikes are most likely the cause of all your woes... including the main board that was replaced.
Apr 01, 2009 | GE PSS26SGR Stainless Steel Side by Side...
Open Questions:
Refrigerators Logo
21 people viewed this question
Top Gorenje Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Gorenje Refrigerator Expert? Answer questions, earn points and help others
