I want to change the password of my wireless router model swc 5100wn
My signal getting weak because many knows my password.
    Scholar:
    New Friend:
  • 149 Answers
That's probably a good idea if lots of people know what it is.
That won't make its signal any stronger, of course.
Posted on Apr 15, 2014
  • 44 Answers
SOURCE: Change password on Dell TrueMobile 2300 router
Hi, logon to your router using IE or whatever browser. Then follow these steps and let me know.
You are prompted for a Username and Password.
Type the username: admin
Type the password: admin
Click the OK button.
The Dell TrueMobile Setup Page appears.
Click the Advanced Settings tab.
A note appears stating that Dell provides the advanced features for your convenience only. Dell technical support representatives can not support the configuration options in the Advanced Settings portion of the setup program.
Click the Administration Settings button on the left side of the page.
Put a check in the box to the left of the Change Your Password setting under the section of the page titled Password Settings.
Type the password that you want to use in the New Password field.
Retype your password in the Retype Password field.
Click the Submit button.
Another window appears stating You have successfully submitted the settings to this device!
Click the Save and Restart button.
Your new password will be saved into the router settings.
Posted on Nov 29, 2008
BlackHand-En
  • 68 Answers
SOURCE: I want to put a password to my wireless network
you will have to use one of the encryption supported by wifi..
try enabling WEP on your wifi router....
Posted on Jan 28, 2009
SOURCE: zyxel wireless router password
you could go to the control panel then network connections then setup wireless network and click on add a network and save the files on a usb then insert the usb to the laptop there you have it you can use internet on your laptop after you install
Posted on Feb 01, 2009
nyilasrobert
  • 627 Answers
SOURCE: how to reset Edimax BR-6204Wg router? default wireless password?
push reset button at least 10 seconds
Posted on Jul 10, 2009
KingDWS
  • 1606 Answers
SOURCE: weak wireless signal - WRT160N is a piece of trash
We found Linksys wifi units to be unusable a few years ago. I had a stack of them that the wifi had died or was unstable or short ranged and none of these were more than a year old. They have had quality problems for about 5 years. Tech support is handled overseas and consists of them reading off of cheat cards. If you get through to a tech you will find them not to understand any technical jargon and once not even normal non technical english.
Our "fix" (and what I'd reccomend if you want to avoidl headaches) was to yank out all remaining Linksys units and replace with a different brand. We didn't see any difference with the models, they all failed in some way. I don't know what happened to the company but they used to have a very good product. They don't have that now.
Posted on Sep 12, 2009
Keep losing signal
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply).
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 28, 2013 | Computers & Internet
Keeps Getting DIsconnected from network
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Mar 18, 2013 | D-Link Computers & Internet
Can i connect swc-5100wn to zyxel p-660r to make a wifi network
Yes unplug power from both devices then connect the yellow ethernet port on the Zyxel modem to the input on the router, there should be 5 ports on the back 4 together and 1 separated slightly from the other 4, plug into the separated port.
The 4 ports toegther are the output of the switch and go to your hardwired computers if any.
Plug in your modem to power, when it has synced back up then plug in power to the router.
Now all you have to do is hard wire 1 computer to the router while doing the router setup and follow the instructions with the router.
Feb 01, 2013 | Zyxel Prestige 660R Router (P660R)
My WRT54G2V1 is now producing a poor or weak signal to the 20nd computer. I have reset it and poeered it down a couple times
Oct 24, 2012 | Linksys Computers & Internet
D link keeps loosing signal
Sep 19, 2012 | D-Link DIR-615 Wireless Router
Why do i keep getting disconnected
There are a few things thatcan cause you to lose wireless connection with your wireless router. 1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up. 2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router. 3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Mar 23, 2011 | AT&T Computers & Internet
Wireless Network Connection constantly reading low/vlow/no signal
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
Jan 04, 2010 | Computers & Internet
Acer Aspire One D250 - Weak network signal strength with Broadcom 802.11g adaptor
Dec 26, 2009 | Acer Aspire One PC Notebook
I cant seem to pick up a very strong signal. Do i need an antenna booster?
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 24, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
