Question about Nintendo DS Console
DS doesn't boot up
Hi, my original DS's hinges recently broke, and I pulled off the top screen, by ripping the cords off the top bit. Now the DS won't boot up. If I press the power button, the light goes green, then the screen flashes white for 2 seconds max, then goes dead. even with a game in either one or both of the cartridge slots will not let it boot up. I am trying to get it so it's only the bottom screen, and only plays Gameboy Advance games, like a more modern GBA. Please help!
SOURCE:
Keeter
  • 41 Answers
SOURCE: Will not play SP games
Did you clean the contacts on the game as well as the system? You may also try setting the GBA back to it's factory settings by turning it on and holding down L,R,A,B and Start
Posted on Sep 18, 2006
SOURCE: Nintendo DS Power On Fault
Did you see this post? http://forums.cdcovers.cc/archive/index.php?t-184492.html
"When you take apart the unit to repair the top screen you'll notice some ribbon cables. The wide ribbon cables go into the clip only one way so there's no problem with them. There is a really small ribbon cable hidden under the wide one. When you put it back together, you have to push the cable in over top of the clip as opposed to underneath which you would normally think of doing. There is a small groove on top of the clip that the cable fits into perfectly. If you put it in underneath, you won't make a connection and the unit will immediately turn off after you turn it on. It's such an easy mistake to make. Of course I made it on two of them. I didn't pay close enough attention to how I took it apart. Hopefully this helps someone else out there that is going nuts over the same problem."
Posted on Oct 15, 2007
winwinwe
  • 28 Answers
SOURCE: Nintendo DS lite won't play nintendo games!!!
You can't produce a code out of mid air............
Posted on Jan 01, 2009
  • 152 Answers
SOURCE: Ds broken? Green light blinks, bottom screen flashes, turns off.
You will have to open it up and desolder the fuse that says, F2, and then solder a small piece of wire onto the two spaces that the fuse sat on in order for you to bridge the fuse because it's probably blown. Then try powering it up. If it works, then you have just repaired it. If it doesn't then there must be another fuse that is blown. Try testing the fuses with a multi-meter. I am guessing that it could be the F1 fuse if the F2 fuse was also the culprit. Do the same thing to bridge the F1 fuse and then it should work.
Posted on Mar 01, 2009
SOURCE: Flashing bottom screen (Nintendo DS Lite)
You need to check the top screen ribbon is fully inserted into to place on the board. A green light and flash of the screen within a second means ribbon not connecting right
Posted on Jun 07, 2009
Ds lite hinge is broken is there an easy fix Right Hinge Broke, Screen Flaps instead of clicking and occasionally goes blank.
beeabe,
I'm sorry to tell you but there is no *easy* fix. If you've had no experience taking apart and assembling a Nintendo DS, I advise you NOT to start with your one and only. It's so easy to rip the LCD cables because they're so thin and you'll have to go buy another.
There are two ways to fix this... Super glue / tape it as much as you can , or send it in for repair or find a local Game repair place.
To fix a broken hinge on a DS, it requires you to disassemble the WHOLE thing. Which sucks when just starting out.
May 30, 2009 | Nintendo DS Console
Nintendo DS hinge broke
You can find the info for replacing the shell here:
http://site.powergamingparts.com/RepairNdsl.html
Dec 22, 2008 | Nintendo DS Console
Turns on and lights up but no images on top screen
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from http://wiinewz.com/forums/nds-general-discussion/72805-ds-top-screen-white-blank.html this appears to be a common problem I hope this helps
Dec 01, 2008 | Nintendo DS Lite Console
Nintendo ds will NOT boot up
you need a new top screen......ebay.
Sep 08, 2008 | Nintendo DS Console
Ds lite hinge broken right h/s (looking at it)this has affected the top screen any ideas please
Hi, it sounds like when the hinge has got damaged, so has the top screen ribbon on the left as its easily ripped. Would need a replacement case and top screen, can recommend here for both: www.console-spares.co.uk, hope this helps.
Mar 24, 2008 | Nintendo DS Lite Console
DS Powering On
Hi, if the bottom screen briefly comes on with a white screen. There is a issue with the top screen, it is either the top screen itself or if there is damage to the hinge it will more than likely be the cheaper option the ribbon cable that threads though the hinge to the top screens PCB board.
Mar 16, 2008 | Nintendo DS Console
Nintendo ds lite
Hi  Im  Patrick here  to  help.First  go  to  a  GAMEFREAK  store
Mar 14, 2008 | Nintendo DS Lite Console
Green screen
There is a ribbon that connects the top screen of the ds to the motherboard. It is possible that this ribbon became damaged when the hinge broke. A possible fix would be to replace the upper screen. Hope this helps.
Jan 07, 2008 | Nintendo DS Lite Console
Nintendo ds
Its possible though sometimes it is expensive so dont worth the work.
-Top screen broken: you can buy a replacement and carefully do the work by yourself with the help of a guide (youtube have many) and some tools (3 winding screwdriver is the less common though not much). The foil data ribbon can be bought separatelly for the original NDS though the new NDS lite have it soldered and very difficult to work.
-Broken plastics: a broken hinge means you need to buy a replacement shell. Anyway buy a complete shell from a DS modding shop or take parts from a non broken plastics DS (water damaged one may be good) in a place like ebay. You would be lucky if you find a non broken screens and good plastics DS for parts.
At the end you may be over your repair budget and not only that, you would be very near to buy a new unit with this money. Each one make its own choice.
Good Luck...
Dec 03, 2007 | Nintendo DS Lite Console
Nintendo DS Lite top screen broke on one side
The only way you can repair this properly is to replace the casing with a new one... the hinge is a common problem and over 90% of my customers on the DS and DS Lite need a new case due to broken hinges. Once the plastic bit has broken then it will only get worse. The small bit that you say fell out was the actual hinge itself (a small black part with a silver end that twists and locks your console into place when open). Hope that helps!
Aug 21, 2007 | Nintendo DS Console
Nintendo DS Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
