Question about Audio Technica AT-PL120 Turntable
Audio-technica atp-2 cartridge with a atp-n2 stylus
The cartridge rest on an angle on the record.
    Novelist:
    Champion:
  • 382 Answers
Make sure the cart is connected properly, and check the manufacter's instruction with that cart. sometimes tonearm height and weights need to be adjusted for proper torque and sound.
Posted on Oct 28, 2007
Fisher mc-715, was working fine until my kid decided to play one of those cardboard records on it, (so he says) now the arm just skips over the whole record.
It will have either knocked out the stylus from it's resting position or broke of the tip.
Here's how to check. Lift up the arm so you can see the underside of the cartridge. The stylus or needle should be seen resting on the cartridge. If it is not there it might have fallen out, but it's more likely from what you describe still there. Next with your finger gently rub the stylus end. It should feel like a sharp point. If it doesn't you will need to replace the stylus. But you might need to do that anyway. All you need is the cartridge number. Put that into google and it should come up with a replacement stylus.
Mar 23, 2018 | Fisher Audio Players & Recorders
Do you know where I can get a cartridge compatible with Realistic turntable Lab2100. RT1500 cartridge, Please. Thanks, PETER
Your RT1500 cartridge is a "P" mount Audio Technica w/elliptical stylus. Google it, you'll find plenty Best Buy and others, ebay.
Jan 10, 2018 | Audio Players & Recorders
I've got an Audio Technica LP-1240 turntable with a Shure M97xE cartridge. I've had it for several days now, and it's been playing fine. I just got a record cleaning kit (Tonar cleaning brush with a bottle...
A damaged or worn stylus will effect all records not just one. I don't know what D4 fluid is, but if there was some still present on the record it could have got inside the cartridge and done some damage to it.
Sep 21, 2013 | Audio Players & Recorders
I'm trying to figure out what type of cartridge the ATP-2 is which came with my Audio Technica AT-PL120 Turntable. Is it "Moving Magnet" or "Moving Coil" or something else?
These are the specs for your cartridge - it is of the moving magnet variety. Vector-Aligned Dual Magnet design and A-T's exclusive Paratoroidal signal generator. This unique signal-generating system is composed of a unified, laminated coil core wound with a single piece of wire. Internal mechanical and electrical connections are eliminated, minimizing magnetic losses and assuring better signal transfer. PCOCC wire
Cartridge Specifications (ATP-2)
Frequency Response 15-22,000 Hz
Channel Separation 23/17 (dB at 1 kHz/10 kHz)
Vertical Tracking Force 3.0 - 5.0 grams
Stylus Construction Bonded round shank
Output 5.3 mV at 1 kHz, 5 cm/sec
Channel Balance 1.5 dB
Stylus Shape 0.4 x 0.7 mil elliptical
Cantilever Alloy tube
Jun 14, 2011 | Audio Technica AT-PL120 Turntable
I bought an Audio Technica USB AT LP 120 Turntable last June. It worked fine as a turntable, but I was never able to get good recordings of vinyl without distortion. But now I have another problem: when...
Sorry it could be the cartridge! They can fail at anytime, only the stylus will wear with time. However it could be the amplifer's magnetic cartridge pre-amp. If you look inside your amp and trace back from the phono socket you should find the pre-amp. If it is distorting on both channels it's probably an IC that has failed.
Dec 05, 2010 | Audio Technica USB Turntable
I just set up my audio technica AT-PL120 for the first time, and I can't stop the tonearm from drifting back to the rest. I can't get the stylus to stay straight unless I add more on to the counterweight,...
KEEP THE ANTI SKATE AT 0 FOR NOW,then you need 2 balance the tonearm with the rear counterweight so it just hovers at around the height of the platter.now you need to zero the gauge on the rear counterweight being carefull not to turn the counterweight,then check again that the tonearm still hovers.then screw counterweight inwards untill the dial on counterweight reads between 1.5- 2 grams dependin on tracking weight of cartridge.then adjust antiskate 2 whatever u set the tracking weight to.i would also double check with a spirit level ur level surface
Oct 12, 2010 | Audio Technica AT-PL120 Turntable
How do you get the stylus off of a audio technica 11-e cartridge? ive got the new stylus to put on, but i dont know how to get the other one off
the end where the black housing should just slide right off.
so pull on the black plastic and that should come out and just slide the new one back in.
Jul 26, 2010 | Audio Technica Replacement Stylus for...
I have an Audio-Technica turntable (AT-PL50). I recently moved and when I hooked my turntable back up, the sound is terrible. It sounds distorted, similar to the sound of blown-out speakers. But, I checked...
it sounds like your cartridge is shot and damaged.
this turntable has fixed cartridge and only the stylus can be changed.
check out this manual: http://www.audio-technica.com/cms/resource_library/literature/0fb01429606842cf/at_pl50_om.pdf
Jun 20, 2010 | Audio Technica AT-PL50 Turntable
Arm's Weight
Not by design.
Tracking Force and anti-skate are preset and unfortunately not adjustable in many modern turntables . You want to be cautious with modifying it if only a couple of your records skip.
If you DO decide to try modifying it consder that the tracking force is in the probable range of 2-4 grams. In the old prehistoric days before T'Ts had adustable tracking and antiskate we would place a dime or penny on top of the cartridge shell to assert the stylus into the groove. THAT is a bad idea unless excessive record and stylus wear is unimportant to you.
Is there anything that might contribute to skipping (not level, scratches, warps, environmental vibrations, loud speakers nearby)?
Apr 01, 2010 | Audio Technica AT-PL50 Turntable
Need replacement cartridge & Stylus
dont know about New Zealand but you could contact this company and mail order it/ship it to N/Z?
mailto:info@needledoctor.com
Sep 27, 2009 | Audio Players & Recorders
Audio Technica AT-PL120 Turntable Logo
631 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Morne Olivier
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
