Question about Ovens
Hotpoint bd32 top oven switch is stuck in and will not turn
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Hotpoint BD32 element not working
Assuming you are talking about the fan oven element, you should be able to feel heat from it , if you are not sure it is working, then you need to remove the rear cover of oven to expose the fan and the element, run it for a couple of minutes, then feel if it is hot, if not, it needs to be replaced.
Hope this helps.
Posted on Nov 27, 2009
barkencoa
  • 3463 Answers
SOURCE: I have a Hotpoint BD32 double oven. The top oven
You need to replace the oven element,, located at the rear of the bottom oven compartment behind a removeable panel.
Posted on Oct 03, 2010
barkencoa
  • 3463 Answers
SOURCE: hotpoint bd32 oven and top
Hi.
You most definitely need a 6mm hard wired supply cable to cooker, anything less, and the cable will overheat .
Under no circumstances connect it to a 13 amp suupply and plug.
The total kw output can reach in excess of 4-5 kw, so it is imperative that you hard wire it to a seperate fused supply.
Posted on Jun 22, 2011
Top oven not working in a hotpoint dh53ck
change the thermostat and check.
Nov 07, 2013 | Ovens
Hotpoint BD32 built in oven is not heating up anymore, top oven/grill works fine. When it's switched on it makes the right "noise" but there is no heat or light. Is this an element problem?
you can check the element, just get a volt ohm meter, set to ohm's and make sure it shows a short, otherwise you have an open or bad element.
Nov 06, 2013 | Ovens
Hotpoint BD32 timer does not work
The timer may be defective.
Dec 23, 2017 | Ovens
Hotpoint bd32 oven and top oven/grill what output does this have .and does it need 6mm cable connection or can it go on a plug
Hi.
Jun 22, 2011 | Ovens
My Hotpoint electric oven no longer heats up. The top oven works but not the main one. How can I fix this?
HI, seen this before with the ge/hotpoint elec. ovens i worked on when i did apartment maintenance. One could be a bad control switch(knob u turn to turn on oven).turn on broiler and see if it comes on,if it does not that could be it.If it comes on it u might have to replace lower element,but could still be control switch not working for that section.But it will one or the other.
Mar 12, 2011 | Hotpoint Ovens
I have a hotpoint ew 52 cooker and the grill does not work. it is part of the top oven.
You need to establish if it is the element that has failed or the control switch, usually it is the element(s)
Aug 07, 2010 | Hotpoint Ovens
Hotpoint BD32 element not working, How can I check if it is a faulty element
Hope this helps.
Nov 27, 2009 | Hotpoint Ovens
Unable to get cooker out of automatic mode
If your oven has timer and it is flashing AUTO then you need to reset it to manual for it to work.
If no timer then it could be a faulty door micro switch, located at the front left side..\Hope this helps, please leave feed back.
Thanks
Nov 25, 2008 | Hotpoint Ovens
Ovens Logo
16 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
