Question about Caterpillar Cat 345b L Engine & Pump Control System Manual
My 345bl excavator engine not get full power - Caterpillar Cat 345b L Engine & Pump Control System Manual
I have 1998 excavator 345bl engine 3176C AND IT GET OVER HEAT after 30 minute of work what can I do to stop the over heat
Not fully conversant with this engine but generally causes of overheating are the following;
not enough coolant in radiator
sticking thermostatic valve
blockage in cooling system
Make sure radiator and reservoir have enough coolant, if reservoir / radiator don't get hot when engine is running then there is a blockage or the thermostatic valve is faulty.
Flush the coolant system with appropriate additive, refill and try again (you can for this use plain water without antifreeze But if it works you MUST ADD anti freeze afterwards.
If flushing system does not work you will have to replace the valve. Unfortunately I have no idea where that will be on this engine , apart from it being near the top of the water cooling systemand directly before any hose going to radiator.
Hope this helps
Oct 07, 2015 | Cars & Trucks
I have 345BL excavator and it start working after 30 m get inute itover heat
There are multiple reasons why an engine will overheat. Lets start with the basics:
1: check that the coolant level is full if it is low top it off with new antifreeze and check for leaks
2: Check to see if your fan belt is there and not slipping. A broke or slipping fan belt renders the fan weak or inoperative.
3: Check to make sure that the radiator is not plugged. Internally by looking into it and seeing if the coolant has turned to muck and also externally. If it is plugged with dirt and dust, it cant shed heat. If this is the case wash it out with a hose or blow it out with shop air. Just be gentle the core is easily damaged. A quick test for an externally plugged radiator is to run the engine and see if the fan will suck a rag to the opposite side of the radiator. if it wont its not flowing air and needs cleaned.
4: Your thermostats are stuck closed and need replaced
5: Your water pump isn't circulating the antifreeze through the system. Look in the radiator and see if you can see the coolant flowing or is it just sitting there.
Oct 06, 2015 | Miscellaneous
Please can you tell me the year of a Kubota KX121-3SS excavator Serial number 30896 ?? Brian
here is a link for Kubota that may help you. It uses the engine serial # to tell you when the engine was built. It doesn't tell you when the engine was installed, though, but it should be very close to the same. http://www.kubotaengine.com/products/engines/engine-serial-number-identification>
Feb 21, 2015 | Kubota Garden
How do I remove the engine on a IHI 35nx mini excavator to rebuild it
Undertaking that major a project, even on a "small" machine like a mini-excavator, should be done using an authorized service manual. I suspect with all of the hydraulics and other mechanicals you really want to be sure of what you're doing. If you're looking for a free service manual, I can't help except to say to consult your local dealer. An online source I found for a manual, albeit for a fee, is found here:
http://www.gciron.com/IHI_Parts_35NX_Service_Manual_Service_Manual_35NX_p/35nx%20service%20manual.htm
Dec 16, 2014 | Mini Cars & Trucks
Cat E70B excavator
Evacuate the hydraulic tank and clean with kerosene.Get as much fluid out of the machine as possible. Replace Filters and if it builds back up with metal SELL SELL SELL it or your in for some big money repairs.
May 05, 2013 | Caterpillar E70B Excavator
Fuel in oil engine Excavator SK200 new engine
you may have a bad head gasket, yes it can happen even in a new engine we are only human.
Feb 23, 2012 | Garden
320 Cat Excavator- engine idles, but does not power up, black smoke come out. Checked the turbo , it's okay. ??????
320 D Excavator Bzp ..., start-up cannot on , there is
error 39: 590-9, please how to solve this problem, what should I check
Sep 03, 2010 | Caterpillar American Construction...
Need aoperators manual for case 9013 13 ton excavator year1999
Just type in manuals.us in your search engine. The operators manual there for a 9013 case is 30.00
Sep 03, 2009 | Milwaukee Tool Case Heat Gun
Caterpillar Cat 345b L Engine & Pump Control System Manual Logo
21 people viewed this question
Top Caterpillar Plumbing Experts
Donni Steen
Tom Chichester
Are you a Caterpillar Plumbing Expert? Answer questions, earn points and help others
