Question about Westinghouse Dishwashers
Electrical burning smell coming from control panel on westinghouse dishwasher
There is a strong electrical smell coming from the control panel. The dishwasher is still working but the further into the cycle it gets the stronger the smell.
  • Kris Holmes
    Kris Holmes Feb 09, 2014
    Forgot to say that the dishwasher is a Westinghouse WSF6602XR.
Had the same issue with a 903sa. Strong burning smell. Continued to run for a while then just died. Opened the control panel (4 screws holding the plastic part at the top of the door on - open the door to access).
Mains feed into the controller was totally fried. Case was all melted. Very nasty. There was nothing obvious on the Board other than a mains resistor that looked like it had been pretty hot at some stage. The three pin mains connector (at least I think it was 3 pins) was just a big, charred bit of goop.
electrical burning smell coming from control panel - 10_24_2015_3_42_46_am.jpeg
Posted on Oct 24, 2015
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 22 Answers
Propably maybe is the wiring of the motor . check if you have noise from downstair a worn bearing causes leakage and noise and after that salt goes to the wiring motor and fries them . its easy to open the control panel first to see if circuit copper is ok . usally smell is wiring from motor or a bad capacitor or ark on the circuit board due to pure contact .
Posted on Apr 10, 2015
    Scholar:
  • 111 Answers
Trust your nose take the outer door sleeve off inspect the control board and wiring I have serviced a few after the board has fried
Posted on Feb 09, 2014
  • 489 Answers
SOURCE: Dishwasher
Yes, have it checked out.  You have a wiring issue inside the door panel that is smoking and needs to be addressed.
Posted on May 02, 2008
SOURCE: bosch dishwasher electrical smell
probably is, hit the breaker
Posted on Mar 31, 2009
  • 7 Answers
SOURCE: Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Posted on Aug 11, 2009
  • 10865 Answers
SOURCE: dishwasher not working
The motor may be burned out or there may be another electrical issue which would also cause the symptoms you describe. Call around and try to get an estimate, and at the same time look at new ones on sale.............one question is how secure will u feel with that maching......now that it has acted up like this.
Posted on Sep 07, 2009
caroldon
  • 17130 Answers
SOURCE: Our Westinghouse dishwasher stopped working
If there is no power to the control panel it must be a failure of the power supply in the unit.
First of all ensure that the mains supply comes into the control panel from the power plug to the unit.
The program controller unit has the power supply within that feed the processor and sections for the program controlling.
Since most of these program controller units are embedded in epoxy it may be hard to service except to check for a fuse link or a visible component failure as probing into to fault find may be difficult.
If so the program controller unit must be changed.
A multimeter must be used to check the voltage to the main unit and the loss of voltage to the microprocessor unit.
Posted on Oct 23, 2010
Why is the dishwasher smelling like electric burning and smoke coming out of the door vent?
Hi friend, thank you for your post!
I understand that your Frigidaire dishwasher is giving off an electric burning smell and you are seeing smoke coming out of the door vent. It could possibly be an issue with your control panel or door vent, both have electrical components inside of them. Since it could be either one of these underlying issues I would recommend having a technician come out to your home and diagnose and repair the dishwasher. Hope this helps. -Matt
Jul 27, 2014 | Frigidaire Dishwashers
Bosch dishwasher smells burning rubber
Certainly could be a pinched wire in the door panel. I would remove the panel and see if anything is pinched or being interfered with like the rinse dispenser solenoid.
Dave
Jul 04, 2017 | Bosch Dishwashers
What is causing the bad electric smell from my dishwasher?
one or more components is burnt on the board of the unit. Or there might be a bridge of wire which is causing the smell....
Jan 05, 2012 | GE Dishwashers
My dishwasher by Frigidaire Gallery Professional Series Model gpd8998jc0 has all lights flashing and could not be started. I smelled burning from dishwasher. Could it be motor burning?
it could be the motor depending on where it's coming. You can remove the lower panel, there are only two screws that hold it on. Look under their and inspect the motor.
Another part that could cause this issue is the mother board. The board is located behind the control panel. Remove the screws around the door frame to loosen and remove the control panel.
On most of these you also have to remove the plastic shielding that cover the control board. To do so remove the three or four screws that mount the board down.
Often these control boards will burn and create a smell like this.
Let me know.
Mar 26, 2011 | Frigidaire Professional Series 24 in....
Maytag Neptune Dryer with strong "burned electrical wiring" smell
Sounds like the motor went out. Before trying to start it it needs to be inspected. If you are not comfortable opening up the cabinet then I would would recommend calling a service tech. If you need further assistance please let me know.
Ken
Mar 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dishwasher not working
Sep 07, 2009 | Dishwashers
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Dishwasher
Mar 24, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Dryer burning smell
Have you painted or stained in your house or apartment recently? The smell gets everywhere, dryer, stove, heating unit. I recently primed with Kilz and the clothes from my dryer smelled burned. When I called for service, it was the first question the service person asked and said they made a lot of useless trips only to find nothing wrong with the appliance. That was my case. I had to rewash clothes and let the dryer run with towels for a while
Jan 22, 2008 | Dryers
Dishwashers Logo
220 people viewed this question
Top Westinghouse Dishwashers Experts
Denis FixYa...
Denis FixYa...
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
