Xmaster hd receiver firmware upgrade - Computers & Internet
I would like to upgrade my iPhone, is it worth it?
In my opinion, you don't have to upgrade. As far as i can see, there is nothing that you absolutely have to have on the iphone 5. And by the time you upgrade and get used to your new phone, there will be an iphone 6 out. Maybe you should wait for the 6 to come out then upgrade.
Jan 16, 2014 | Apple iPhone Smartphone
Yamaha rx-v663 is there a firmware update to get hdmi 1.4a support ?
Unfortunatly there is not any firmware to upgrade your unit to a higher HDMI format. There is a firmware though that corrects the following symptoms.
1. In case of playback of some DTS-HD Master Audio stream, pop noise may be generated.
2. Test tone may not be output under specific YPAO condition.
3. When test tone is output from presence channel, surround R channel is simultaneously output when speaker settings are PRESENCE SP "EXIST" and SWFR "NONE".
4. Multi channel input setting will be reset after power off the unit, in case of setting "INPUT CH" to "8CH" and "FRONT" to "VCR" or "V-AUX".
Apr 10, 2012 | Yamaha RX-V663 Receiver
Toner exsusted replace toner
To solve problem you need to download PATCHED by scx4300.exe 1.13 firmware (which you can Google and download it online)where additional reset procedure was implemented in.
To patch firmware you need to unpack archive in any folder then open commad line interface go to this folder then type "fix4300.exe SCX4300_V1.13_Fact_romdl.hd". If no error occurs you will find file "FIX_SCX4300_V1.13_Fact_romdl.hd". It's a patched firmware. The next step is to download this file to printer. Enter TECH mode, activate download by "Menu > Data Setup > Flash Upgrade > Local [OK]" then type in command line "usbprns2.exe FIX_SCX4300_V1.13_Fact_romdl.hd" to start download. During download printer displays: Data receiving > Flash erasing > Flash Programming > Checksumming > Download Ok then printer will restart. It's all.
To reset all counters and unblock printer enter Tech mode go Data Setup > Clear counters. In this menu you will find "Clear All CNT" instead of "Total Page CNT". Choose "Clear All CNT" then press [OK]. Printer will display "warming up" and LED will yellow for seconds then change to green. After reset all counters in report will be zero and toner 100%. You may repeat this procedure as soon as you need.
Feb 01, 2011 | Samsung SCX-4300 Monochrome Laser...
I have a total of two standard tv's currently connected to my Dish receiver box 322. I would like to upgrade my main tv to a LCD tv. Can I still keep the 322 receiver or will I need to upgrade to a HD...
Hello, this is Nick Franta with DISH Network Customer Support.
You can still keep the 322 receiver with your new LCD tv. An HD receiver upgrade would be beneifical as well to make sure you maintain the best picture quality.
This link may come in handy for HD upgrades: http://www.dishnetwork.com/faq/default.aspx?Category=Existing%20Customer%20Promotions/Upgrades
If you have any questions let us know!
Dec 18, 2010 | DISH Network 322 DTV Receiver
I'm trying to use the recording function on my Teac HD-B6T digital tv receiver but it doesn't recognize the hdd when I connect it. Do I need to use a special hdd with the receiver?
Have you updated the firmware?
See
http://www.teac.co.nz/brands/teac/Service/Product-Upgrades/?searched=hdb6t&advsearch=oneword&highlight=ajaxSearch_highlight+ajaxSearch_highlight1
May 21, 2010 | Televison & Video
I ripped Bluray movies using "ANY DVD HD" to my hardrive then playing them through "WD TV Live HD Media Player" (using HDMI cable to Sony Bravia HD L.C.D.TV) some movies work good but others play the video...
Either check around in Any DVD HD or the BluRay menu to set audio output to PCM, which doesn't require any decoding to play back properly or you will have to convert them separately.
Nov 30, 2009 | Western Digital TV HD Media Player USB...
HD TV not passing the tests offered on network tv
Which network? Cable? Satellite? Dish or Direct?
With any of these providers, you should get an ATSC or "digital" signal. If not, the problem would most likely be with the service provider since they are converting the signal for you. The only way that your set would be affected is if you have an "off air" (antenna) signal only. At this point you would need a converter box. If your service provider is providing you with a HD receiver, then you should have no problem recieving HD (as long as your paying for HD). However, keep in mind, digital is NOT HD. If there is an incompatability with your receiver, check with your service provider for a software or hardware upgrade. Also, check with your local TV serviceman to find out if there are any software upgrades (firmware) for your TV. Being three or so years old, it is possible.
One last thing to check is to see what type of signal you are passing from your providers box to your TV (which type of cable". At a minimum, you need a "component" connection to pass HD content. A "composite" signal is standard definition. Best you can get right now is an HDMI cable. Best "one cable" source for video and audio.
Good Luck.
Tim
Certified TV
Jan 23, 2009 | Sanyo DP32746 32 in. LCD Television
Hp 2420 service code 49 2F90 what does it mean?
A critical firmware error has occurred.
Go to http: www.hp.com/
support/lj2410, www.hp.com/
support/lj2420, or
www.hp.com/support/lj2430.
Click Download Drivers and
Software
. Check for the
latest firmware image version
at the bottom of the page. If
this firmware image is newer
than the one installed on the
printer and the printer can
receive a firmware update,
download the newer firmware
upgrade. Not all printer
models can receive firmware
upgrades.
Failing that replace the formatter
Aug 13, 2008 | Office Equipment & Supplies
Firmware Upgrade
Where did you get the firmware upgrade? Please provide link.
Mar 05, 2008 | Yamaha RX-V2700 Receiver
I do not feel comfortable performing the installation the Optional Enhancement Upgrade for DiMAGE 7, can I have the camera upgraded professionally?
If customers do not feel comfortable upgrading the DiMAGE 7 firmware themselves, they can send the camera in to the NJ repair facility with a note stating "Please Upgrade Firmware". Their camera will be upgraded, and they will be charged $49.95 (plus tax and shipping). They will receive back their upgraded camera, and a DiMAGE Viewer Ver 1.2 Upgrade CD-Rom*. (They will not receive the firmware upgrade on CD-Rom or the new DiMAGE Viewer) There is a 2-3 week turn around time once payment has been authorized. * images captured with an upgraded camera cannot be opened using previous versions of the DiMAGE Image Viewer Utility 1.11 or earlier. A DiMAGE Viewer Ver 1.2 upgrade CD-rom has been bundled with the DiMAGE 7 Optional Enhancement UPGRADE Firmware. The previous version of DiMAGE Image Viewer Utility must be installed before the DiMAGE Viewer (Ver 1.2) update can be loaded. If customers do not feel comfortable upgrading the DiMAGE 7 firmware themselves, but they want the DiMAGE 7 Optional Enhancement UPGRADE and the New DiMAGE Viewer 2.0, they should purchase the kit through our on-line store, then send the camera in to the NJ repair facility with the Firmware UPGRADE CD-Rom that they purchased. As long as the firmware CD-Rom is sent with the camera, and the camera does not show damage that may void the warranty or cause the firmware to not install properly, there will be no charge for the camera to be upgraded. There is a 2-3 week turn around time once the camera has be received. If customers attempt to install the firmware upgrade on their camera and experience a problem, or the upgrade does not complete, they should send the camera in to our NJ repair facility with the Firmware UPGRADE CD-Rom and a description of the problem. As long as the firmware CD-Rom is sent with the camera, and the camera does not show damage that may void the warranty or cause the firmware to not install properly, there will be no charge for the camera to be upgraded. There is a 2-3 week turn around time once the camera has be received.
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
