Question about Samsung 793S 17" CRT Monitor
May iknow resistor value of r620 - Samsung 793S 17" CRT Monitor
What is the value of resistor 601
600 ohms
A resistor with a number code instead of a letter code is a SMD:
Surface Mount Device. You might have searched for SMD resistor code and got some hits.
The system for SMD resistors is:
1st value-2nd value-multiplier
6 - 0 - 1 following zero
= 600 or 600 ohms
603 would be 60,000 Ohms or 60k
6 - 0 - 3 following zeros
Mar 21, 2016 | Televison & Video
Resistor value of R704 of Sharp tv model 21v-fk200m
How do i unlock sharp crt tv model 21v-fk200m? i forgot the ...
www.fixya.com/.../t25439922-unlock_sharp_crt_tv_model_21v_fk200...
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
Dec 28, 2015 | Sharp Televison & Video
Can anyone tell me the value of the resistor in a Kitchenaid K5A mixer. I think mine grew legs and walked away. Thanks, Mike
Are there any colors on the resistor or it is missing. If you know what the voltage and current should be in the circuit you can calculate the resistor value.
May 08, 2014 | KitchenAid K45SS Classic Stand Mixer
Scania r620 running hot
Hi, Try replacing the thermostat. It's a valve that opens when engine gets hot. When it doen't work properly engine temp will rise. Good luck.
Jan 21, 2014 | Italeri 1/24 Scania R620 and Semi Trailer
R620-63g bios password
BIOS passwords can be reset or removed in two ways:
1. using software 2. using hardware..
I would first try resetting or removing using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html&act=down
CmosPwd - Cmos password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
You will need to create a bootable Dos, or Linux or NT cd in order to run them.
Good Luck!
Sep 03, 2012 | Samsung R620-63G Notebook
Radio Shack Multimeter, 22-168a, shunt resistor value????
Go to the Radio Shack site and you may with the model number find a schematic or you can email/contact them for the value of the resistor.
I predict it is a precision value and type you will have to get from them if available.
PS: you posted in wrong catagory as this is TV section.
Mar 12, 2012 | Televison & Video
I have two crack green resistors colors are red, brown silver gold. what value is this. Its on the power board of a 24 dell monitor
The value = 0.21 ohms 5% tolerance
Use this WEB site to work out the value of the resistor.
http://www.smpspowersupply.com/resistor/resistorcolorcode.html
This WEB site gives you the color code values for resistors.
http://www.google.com.au/images?hl=en&q=resistor+colour+code&um=1&ie=UTF-8&source=univ&sa=X&ei=YHRsTfSsK5C2vQPA353UBA&ved=0CCsQsAQ&biw=1024&bih=416
Mar 01, 2011 | Computers & Internet
Security light flashing eng. will not spin over ign.lights will come on battery is hot i can short the starter soln.wires with screwdriver it will crank and run for just a second and go dead check all...
the key could be the issue. in which case u would have to take it to a shop for them to reset the key. it could also be that the security system has been activated in which case it would have to go to a dealer to reset the anti theft system. sorry i couldn't be more help
Oct 17, 2010 | 1995 Chevrolet Lumina
I have a resistor problem in sanyo ST-21G1
it's very difficult to give the exact value of that resistor.,but i can give some tips to find the value of the said resistor .( find how the resistor works, it is a dropping or fusable? if fusable used .47 or 1 ohm resistor if it is a dropping resistor you should make a trial and error .from 100k,10k or 1k.
Oct 29, 2008 | Televison & Video
Sony resistor values?
It is recommended to use the same value due to the function of the resistors and their values.
A lower value will let the current flow a bit faster and the higher value will slow it down according to their design.
Try installing the same value of 220 ohms.
Hope this helps.
May 05, 2008 | Audio Players & Recorders
Samsung 793S 17" CRT Monitor Logo
14 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
