Question about Tablets & eReaders
Egm002 reset unlock factory default
Can you get bluetooth or playstore on theese
if you are referring to 7 Multi Touch Tablet . Look at the specs page https://ematic.us/shop/egm002.html#Tech-Specs
It does not support Bluetooth and cannot be added.
It is hardware component and cannot be added from playstore.
Apr 19, 2016 | Ematic 7" Touch Screen Tablet
Won't let me reset password its like it is hung up. turning it off won't help. what do I do?
If you do not remember the password, or is you cannot enter a password, it is likely that you will need to do a reset. Unfortunately this will reset the device to its factory defaults, so any data you have stored locally, will be deleted in the process. If you moved anything to an external SD card, just remove it prior to the reset,
Unlock forgottten password pattern lock of Android Tablet
How to Reset an Android Tablet
How to Factory Reset Your Android Phone or Tablet When It Wont Boot
I post on behalf of HP.
Jul 27, 2015 | Tablets & eReaders
How to do a factory reset on a Koboarc7
Watch this video: Remove Forgotten PASSCODE PASSWORD Unlock For ALL Android Devices...
Caution: you will lose all apps you added and data, since the hard reset sets it to factory defaults as though it was new.
Nov 14, 2014 | Kobo Arc
Newtablet,putpassword in now it won,t let me in
You can do a hard reset as shown on this video:
Remove Forgotten PASSCODE PASSWORD Unlock For ALL Android Devices... But it resets to factory default, so you lose all apps & data YOU added.
Nov 13, 2014 | Tablets & eReaders
My kid locked her dl700d and now she cant unlock it
Typically only a factory reset will unlock it if the password is lost. It will wipe all data stored and reset to factory defaults. Then you can use it again as though it were new.
Sep 13, 2014 | Tablets & eReaders
I HAVE FORGET MY PASSWORD
I am afraid you will probably have to reset your tablet to default settings and loose all your info on it.
Press and hold + volume button and start the tablet.
It will give you 3 options. Select erase all data and factory reset and it will reset to factory defaults
Jul 21, 2014 | Apple iPad (16 GB) WiFi Tablet PC
PATTERN LOCK PROBLEM
If you have forgotten your lock code you can try default codes like 12345 or 0000 or 01234, if it doesn't work you can reset your phone with the help of Unlock-Free.com where you need to mention your phone model and IMEI number...
Note:They provide master reset codes (free) for old models of Nokia and Allcatel.. Unlock Free com
Mar 04, 2014 | Tablets & eReaders
I cant remember my draw pattern to unlock
just make a factory data reset.
To reset you tablet manually. you have to
1)switch of your tablet
2)hold volume down button and power button at the same time.
3)wait for 10 sec and you will enter into boot menu.
4)there in the boot menu you will find option named Reset factory default settings/reset user data. select that option
5) wait for resetting......
6)cheers your done.
Mar 01, 2014 | mid Archos M729B Android Tablet
Pattern unlock
About the only thing you can do is a factory reset of the device. As a security feature, however, you will lose any data stored on the tablet when everything resets to factory defaults.
To reset the device, press the (POWER) and the (VOLUME +) buttons together and hold them down for approximately 10 seconds, when you see the android logo, release the buttons and follow the on screen menus.
If this isn't something you are comfortable doing, give me a call during business hours tomorrow.
Hope this helps...
Mikeal
Dec 19, 2013 | ViewSonic G Tablet 101 Multitouch Android...
I can't unlock my nextbook tablet
If you're willing to reset to factory defaults, then there is a way to fix this. However, the reset will delete all data and any apps installed that didn't come with the Nextbook Tablet originally.
Dec 18, 2012 | Nextbook Tablets & eReaders
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
