Question about Peavey Xr 8600 8 Channel Powered Mixer
I have a Peavey 8600D can I safely run 1 main
I have just bought a Peavey 8600D and 2 Peavey PR15 speakers, to save space and for lower volume gigs, can I safely run just 1 main speaker? does it matter which side to plug in? thanks
  • Peavey Master
  • 10,137 Answers
When you unload one amplifier you stand the chance of killing the amp's output transistor. If you must use only one speaker, you have to bridge the amps.
Posted on Jun 23, 2015
4 Suggested Answers
  • 1138 Answers
SOURCE: i would like a wiring diagram for peavey pro 15
Here is their support page if it helps:http://www.peavey.com/support/ Also try this link:http://forums.peavey.com/
Posted on Mar 02, 2010
  • 5603 Answers
SOURCE: whats the wattage of the bulb used in peavey sp2
The lamp is an "1156" lamp... replace with that part number. Here :
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=524517&k=lamp%201156
Or you can find it at auto parts store.
LIKELY the polyfuse device is ALSO gone... Probably similar to this one (1.1 amp, trip 2.2 amp):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2010-ND
or this one (1.85 amp, trip 3.7 amp):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2013-ND
Posted on Jan 11, 2011
  • 52 Answers
SOURCE: Wires to main speaker are, Yellow & Blue
Yellow should be the positive. Try plugging in and reversing. The louder of the two is the one in phase and the correct wiring. If the speaker is pushing out when playing , it is in phase and correct also.
The distortion problem could be a speaker going out. It may not be totally blown, but may be verging.
Holding your hand out as wide as you can push against the speaker lightly. If there is a rubbing or scratching sound, the speaker could be damaged.If it moves freely, and there is no scratching its okay.
Another possibility is the clean channel may have a channel volume set to high. Make sure the clean channel volume is set lower than the master volume otherwise you can get distortion on that channel too.
Good Luck.
Posted on Feb 21, 2011
How do I connect my Bose l1 compact to Peavey xr 8600?
You would come out of the Main output on the front of the mixer into the line in on the Bose.
You may find this site useful- L1 Unofficial Performers Guide
Jun 25, 2015 | Peavey XR 8600D Class D Powered Mixer
How do I connect a rack mount effects processor to a Peavey 8600D mixer?
  1. On the front panel you want to take a 1/4" cable and plug it into the "main" (output), and then connect it to the input of your fx unit (left is usually mono, if not it will be marked). Then take the output (corresponding to the input) of the fx unit and put it in the power amp in. The 8600D is NOT a stereo unit (this is why there is only one main output).
May 17, 2014 | Peavey XR 8600D Class D Powered Mixer
What is the jack nut thread size for Peavey PR15
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Jan 03, 2014 | Peavey PR15 400w PA Speakers
Peavey speakers making no sound
Try connecting them to another amplifier...you can use the speaker output of a guitar amp as a quick test. If the amp (and mixer) check OK, it sounds like you are about to become good friends with your local speaker reconing shop.
Remember...Distorted Audio Can Kill Speakers even at low volumes. It happens because sine waves become square waves. Google it for additional information.
Oct 24, 2012 | Peavey PR15 400w PA Speakers
Peavey Pr-15 fuse blown, speaker not working. What is the fuse rating
Actually its pretty funny thing with those speakers is the "fuse" is Actually called a Lamp in this case. These are what they call a " Red Dot Fuse ". in all the years i've been doing this i've never thought to look up the value haha. Just have to know there are Red Dot lamps and Blue dots and No Dot. If you examine the LAMP you should see somewhere close to the ends ON THE GLASS a color dot of some kind. almost like someone painted it on there. Red Dot Lamp. any parts distributer for people like Harbinger, Peavey, and B52 will KNOW what your talking about
Aug 21, 2011 | Peavey PR15 400w PA Speakers
The blue and red cable came loose on my peavey pr 15 neo 2 way speaker
Put the red on the + side and the blkue on the - side. SECURE the wires so that their weight does not pull them loose again. You can pop amps when speakers come loose...
Jan 02, 2011 | Peavey PR15 400w PA Speakers
Can i connect the pv 112 to the pv 118 subwoofer since the powered mixer i bought it only has 2 main outputs? The powered mixer I bought is the PV XR 8600D powered mixer...
Generally speaking you should only send low frequencies to subs. The highs, while lower in power than the lows, will over time harm the voice coils. The ideal way to do this is to use an external crossover netween the main output and the amp input with the higher range going to a general set of speakers. Send the lows through the second channel of the amp and then to the subs.
In short, while not recommended, yes you can hook them up in parallel.
Dan
Dec 09, 2010 | Peavey Pv118 1x18" Subwoofer Speaker...
What kind of fuse does peavey pr15 passive use
Here is a site that has PR15 fuses... shown as a 2.1 amp. Very strange value, and it must strictly be for the tweeter portion as 2.1 amps is nothing for a speaker... I don't know that I believe this site.
If you have a Guitar Center near you, inquire there.
Dec 28, 2009 | Peavey Music
Peavey Xr 8600 8 Channel Powered Mixer Logo
116 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
