Question about Belkin My Essential (ME1004-R) Wireless Router
My wireless router is beeping continuously - Belkin My Essential (ME1004-R) Wireless Router
Hi!! i ordered this router from walmart.com . But it didnt come with the set-up wizard cd. My son has a playstation 3 and is trying to connect to the router. He told me the we needed the wpa2 key but it...
  1. To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1).
  2. Enter the user name (admin) and your password. Leave the password blank by default. If you get a Page Cannot be Displayed error, please refer to the Troubleshooting section for assistance.
  3. Wireless settings for the router may be configured manually or by using a wizard. To use the wizard, click the Wireless Connection Setup Wizard button and then follow the steps that are described below. To configure the wireless settings manually, click the Manual Wireless Connection Setup button. The Wireless Security section that directly follows this Configuration section provides additional explanation for how to configure the WEP, WPA, WPA2, and WPA/WPA2 wireless security mode options.
  4. Click Next to continue.
  5. Enter a Wireless Network Name in the textbox, which is also know as the SSID and select the desired level of wireless security, WEP, WPA. and then click Next to continue.
  6. Enter a Wireless Security Password in the textbox and then click Next to continue.
  7. This window displays a summary of your wireless security settings. Please print this out or record this information in a safe place and then click Save to continue.
  8. The Router will save your new settings and reboot. When it is finished after 1-2 minutes, the opening Wireless Setup window is displayed.
Here is the Manual for your Router:
ftp://files.dlink.com.au/products/DIR-600/Manuals/DIR-600_B1_Manual_v2.01.pdf
Feb 15, 2011 | D-Link DIR-600 Router
Netgear N150 Wireless usb adapter just installed. It identifies router and confirms good connectivity, but continues "acquiring network address" without success.
This means the DHCP service is not enabled on the wireless router.
either enable the DHCP service on the wireless router
or
Give a static IP onto your wireless NIC card ( Netgear N150 Wireless usb adapter )
Dec 06, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
My D-Link Router 615 keeps cutting out after a few minutes of working. I have no problems when I connect the ethernet cord directly to the modem.
Please check the wireless signal quality and strength you are getting from the wireless router.
Please do a continuous ping to the wireless router IP.
ping -t "ip of the wireless router"
Oct 31, 2010 | D-Link DIR-615 Wireless Router
D-LINK wireless router does not work
if you can enter router configuraion site you needs to continue setup wizard or try it manualy by getting to ip configuration site
192.168.0.1
or try to reset router for 1 min
May 01, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Help!! Router Channel problem
eh if your turn of the power or the power goes, why or how can you have wireless because the power is gone ?? is like trying to drive a car with no petrol in the tank.
Nov 30, 2009 | Gateway Wireless-B Router (wbr-100)
I have the d-link 524 that i use to connect my xp laptop via wireless connection and my vista desktop through a hard connection. What I found is that my wireless connection continually goes down and will...
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 13, 2009 | D-Link AirPlus DI-524 Wireless Router
NETGEAR WGR614 Wireless Router keeps beeping
try by upgrading the latest firmware version from netgear website
Dec 15, 2008 | NetGear WGR614 Router
Help with a WRT54G wireless router
Yes sure we can, do you have a program like MSN messenger so we could continue to chat live.
In any case, does your laptops wireless detect the router?
Mar 26, 2008 | Linksys Wireless-G WRT54G Router
Belkin My Essential (ME1004-R) Wireless Router Logo
53 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
