Question about Mastercool 67680 Evaporative Cooler Air Conditioner
Smell in house after evaporative air conditioner pads were changed.
After changing the wooden pads to my Bonaire SGS evaporative air conditioning unit and restarting the unit a horrid ***** type smell is now prevalent in the house. This did not happen last time I changed these pads and I have been told by the supplier that the pads have been changed. My first test to overcome the smell was to add about 500mls of Pine O Clean. This had virtually no effect. 3 Hours later I have added 2 litres of brown vinegar. An odour in the house still lingers but its no longer like ***** but now more like glue. Overall this is more acceptable and I have much aeration throughout the house at the moment. Is there an alternative and better solution for this odour problem. The air conditioning unit was cleaned prior to the change and the odour is clearly not directly related to the units condition.
Ed Phillips
  • 11 Answers
SOURCE: New Mastercool pads smell bad
The cellulose pads in a mastercool are glued together and usually the adhesive is what you smell. It may take a while for it to go away. Strange as it may seem, as the pads get more mineralization and you use it more the smell will go away. Do not use a cooler for your whole house without plenty of exhaust through a window or an updux. Coolers work best when there is plenty of freely moving air.
Posted on May 31, 2009
pierre1811
  • 144 Answers
SOURCE: Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Posted on Jan 29, 2009
  • 400 Answers
SOURCE: We have a Vulcan Bonaire evaporative cooling unit
The problem may be with the drainpump not functioning properly. They sometimes clog up with scale. Easy to remove and clean by opening up the unit. Some units also have an alarm function when the cell pads need replacing. Again this one would be able to see visually. They simply slide out, you would have to locate a supplier and just buy four cellpads.
Posted on Mar 04, 2009
dunnomuch
SOURCE: Question regarding Mastercool Evaporative Cooler
This is just a slight possibility. You may have inadequate exhaust. Open more windows or doors. For every 1,000 CFM of air delivery 2 sq. ft. of unrestricted air relief is required. Check the water distribution system for insufficient water to the pads. Check the pads to ensure they are not clogged and clean if needed.
Posted on Jun 25, 2009
  • 35 Answers
could be the float valve is stuck or has some object blocking it so it cant cut off the water flow..( adjusting the float hight, or cleaning will solve this) or could be the plastic inserts that carry the pads are cracked & allowing water to escape the unit.( replace the pad carrier)..
If your going up on the roof to fix it... you may as well get a onedose cartridge from the hardware shop & put that in the tank whilest your up there...
Posted on Nov 10, 2009
Bonaire vulcan evaporative air conditioner
check your filter for dirts, clean or change it, check your evaporator and condenser coil and clean....
Jan 29, 2014 | Heating & Cooling
I have a bonaire evap system cant get it to come on have changed batteries and reset it still nothing happens the remote is called bonaire comfort control have recently brought the house and cant find an...
Remotes are a pain. Can you get into the unit to see the control box? You need to see if the unit has power. If its new enough it will have some diognostic lights so you can see if it has power. Without that its hard to diognose. Unit Model number is also helpfull. if it looks like the one on this picture it will be etched into a badge on one of the corner pillars. if its a plastic unit it will be on a sticker inside the unit
Feb 24, 2011 | Mastercool 67471 Evaporative Cooler Air...
Our bonaire evaporative unit will not switch on. l rang customer service and they advised l reset the unit as we recently changed the batteries l did the reset but the unit still does not work and after...
try reset the controller. turn off power to the unit then remove batteries from controler. press the power button on the controller to remove residual power. turn on the unit then install batteries. turn on controller within 4 minutes of turning on unit
Nov 23, 2010 | Mastercool 67471 Evaporative Cooler Air...
Bonaire evaporative water keeps running whne the unit is turned off
I would check electric solenoid valve on water line to make sure it is shuting when power is off to blower. Some of these valves can be taken apart and cleaned if it has debris stopping valve ffrom fully closing. To do this shut power off to unit, shut main water supply to cooler. Usually there are four screws holding top cover on valve remove these,remove cover and clean valve. Reassemble making sure that cover gasket is in good condition and properly placed. Turn water and power back on and try unit. Hope this helps you. Thanks
Nov 11, 2010 | Mastercool 67471 Evaporative Cooler Air...
Ive got a mildewy smell coming from my evaporative cooler how do i get rid of it?
This unit needs to be serviced. Try replacing the pads with the sponge like pads.Drain the old water and clean up the pan and pump area. Go down to a pool supply store and buy some chlorine tablets and add to the water. In fact, they make these tablets just for the evaporator units. There are 3 states to water, solid, liquid and gas,
. This will get rid of the smell.
Sincerely, shastalaker7
Oct 28, 2009 | Mastercool 67471 Evaporative Cooler Air...
Do not know how to work/maintain swamp cooler
Make sure you have water to the unit, the water pump is on and the fan is working. No water=no cooling.
Apr 21, 2009 | Mastercool 67471 Evaporative Cooler Air...
We have a Vulcan Bonaire evaporative cooling unit and the control panel is currently flashing on and off and there is a really annoying beeping sound every 30 seconds. We bought this house with the system...
Mar 03, 2009 | Mastercool 67471 Evaporative Cooler Air...
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
53 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
