Malber P28 Front Load All-in-One Washer / Dryer
Problem for Malber P28 Front Load All-in-One Washer / Dryer
Water runs into drum when machine is off!
By lfrankooh on Jun 07, 2009
This is a Malber combination washer/dryer. With it hooked up to water, the water runs into the drum even though the machine is not turned on. I empied about 2 gallons of water from it. Any ideas??
Best Solution
posted on Jun 07, 2009
Very Helpful)
zeusfaber
Rank: Guru
Rating: 87%, 344 votes
See what happens if you completely remove electrical power from the machine (by turning off at the wall, or unplugging it) If the water keeps coming in even with the power off(easily the morelikely outcome), then you need to replace the fill valve. On most machines, you get to this by taking the top cover off and looking inside at the point where the water inlet hose comes in. The plastic fitting that the hose screws onto is in fact part of the valve that you want to replace (you'll recognise it by the row of solenoid valves - 2 or 3 of them, each with a pair of wires on the top, and a hose trailing off to some part of the machine coming out the bottom). Fitting a new one is quite easy - just make sure you mark all the hoses and wires before you remove the old valve so you can put them all back in the right place. If the problem goes away when you turn the power off (a far more unlikely result), then you need to look for problems with the programmer and wiring. Tracking these down is a lot more involved, and potentially more expensive. A.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Malber P28 Front Load
Questions and Unsolved Problems for Malber P28 Front Load
Do you recommend Malber P28 Front Load All-in-One Washer / Dryer?
Answer
Answer
Macine is not taking powder and softener from the draw
Answer
How do i replace the bellows on a lgwp1300qs washing machine
Answer
The door is just round with a hole. The wash happens - the light switches to end and I can't get... (More)
Answer
Door does not open. Is there an emergency release or something?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machines Experts
Top Washer & Dryer Repairmen
in San Mateo, CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
