How to manually adjust the developer for konica
I just reset the unit Konica 7135 refresh all data and it displayed " please adjust L detection" I tried L detection mode but it does even make a motor and just for only 1 second it displayed its value as 006 I don't think that installing new developer will make a difference cause the unit does not run at l detection mode?? thank you for the reply!
3 Suggested Answers
firecontrol7
  • 6161 Answers
SOURCE: I Have konica 7130 i can t Made L detection The
Code 0006 TCSB (toner control sensor board) output signal D/A conversion error To Clear SW2 (sub power switch) OFF/ON Problem Solutions, Replace 2? PRDB (printer drive board) 1? TCSB (toner control sensor board)
Posted on Aug 05, 2009
roytardio
  • 106 Answers
SOURCE: i have a problem of
off the machine ,hold 2and 5 simultenously then on the copier press software switch then go the # 16-0-0
16-1-0
16-2-0
16-3-0
16-4-0
16-5-0
16-6-0
16-7-0
Posted on Jun 13, 2011
Konica minolta bizhub 215 giving error c2558
C2558
Abnormally high toner density detected TCR sensor board
- The T/C ratios detected by the TCR sensor board (TCRSB) are above the threshold for the detection of abnormally high T/C ratio for three successive times.
- The connector between MFPB to TCRSB is disconnected.
Error Codes Konica Minolta bizhub 215
Mar 07, 2015 | Konica Minolta Office Equipment & Supplies
How i can adjust the position of the Touch Panel display konica 7020
Go to Touch Panel adjustment you will see "+" to the 4 corner of the touch panel use pointed object point it MILD on the center of the 4 "+" . Off / On
Oct 06, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Hooper assembly is not working in coping but working in 47 mode
remove the drum assy. and have the the drum and developer replaced along with having the drum and developer assy. cleaned and the senors that are on the assy, then have the proper procedures run after the developer and drum are installed, ALSO have the counters reset to let the copier know that new developer and drum have been replaced
Apr 10, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Hooper Assy on off Code
sir/mam
Remove the drum assy. and have the the drum and developer replaced along with having the drum and developer assy. cleaned and the senors that are on the assy, then have the proper procedures run after the developer and drum are installed, ALSO have the counters reset to let the copier know that new developer and drum have been replaced
Apr 10, 2014 | Konica Minolta Office Equipment & Supplies
Copy of konica 7135 is unclear while running. at first is copy is clear, later the copy is not clear... blurred
try to make some copies from your pc if the results is ok that simply means something with your scanner unit, for exaple the pnnel needs to be lubricated and the ccd unit needs to be cleaned.
Mar 20, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
7135 DEVELOPER IS EMPTY IN 2 DAYS
have a possible cause developing unit ,charging unit ,transfer unit
May 28, 2011 | Konica Minolta Office Equipment & Supplies
C-0F32 FOR KONICA MINOLTA BIZHUB C350
Abnormally low toner density
detected Magenta ATDC Sensor
T/C 0.21 % or less is detected ten consecutive times
in the Developing Unit as validated through the toner
replenishing amount determination control.
Check Developer unit, check toner supply ratio in the service mode, under Image Process control and make sure that Toner motor is sping and adding toner into Dev. unit.
Also check and see if you have enough Developer. clean ATDC sensor and run Image Quality adjustment
Apr 13, 2010 | Konica Minolta Office Equipment & Supplies
Konica Minolta bizhub 210 error m2 appear on display
Hi
You can reset (M2) by reset clear data
Enter to service mode By Pressing :
Utility - clear -0 - 0 - clear -0 - 1
Press ADJUST
Press CLEAR DATA
Turn OFF Copier and Switch it ON
Feb 28, 2010 | Konica Minolta Office Equipment & Supplies
Displaying mualfunction detected (bizhub 250)
i will like to know how to reset the page count and service my konica myself, also my konica bizhub 250 is showing C-0204
Feb 22, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica 7020 copier
what happens when u run L-detect. Make sure the sensor near the drum sep claws in the drum unit is clean. Any toner or setting powder on this semsor will give u errors while running L-detect.
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
jasbo
jasbo
