Question about Peavey Electronics PEAVEy PEAVEy 8 CH USB MIXING BOARD PV8USB
Clip light stay on pv8 - Peavey Electronics PEAVEy PEAVEy 8 CH USB MIXING BOARD PV8USB
Pv8 setup karaoke
Are you using a karaoke machine? Make/model?
May 03, 2014 | Peavey PV8 Mixer
Clip light on
Does all the "Clip" lights are on? or just certain channel? if all "Clip" lights are on you have to check the +15V and -15V at Operational amplifier ic that is a 8-pin integrated circuit, pin 4 should have the -15V and Pin 8 should have the +15V, if just one channel shows the light constant on then its an opamp in that particular channel, let me know further to improve help.
Oct 24, 2013 | Peavey PV8 Mixer
Amp 5050 rmx stay in clip mode
Disconnect speakers. With NO input, if clip light remains on, take in for repair as there is an internal failure. If reducing the gain and loudness keeps the clip off, then you are probably driving the amp too hard. This is common problem when the user "thinks" they need it louder but the amp speaker combination will not deliver louder. At this point, both the amp and the speakers are at risk of permanent damage requiring repair.
Sep 22, 2011 | Qsc Plx-2502 450w Per-Ch. 8 Ohms Amplifr...
I can`t get any sound from my pv8 mixer i put the speaker cable i have put the red & white phonos into the mixer from my laptop getting on sound from the clip at all please can you tell me where i am...
Several things to do: Plugging into the tape type inputs... say the 7/8 channel.
The little button below the set you plug into needs to be pushed to the down position. This selects the "B" set which are the RCA jacks.
Below the set you are plugged into. Turn up the top knob "Gain" until the "clip" LED just isn't quite flashing.
At the bottom of that same column Turn up the "level" as needed for the mix.
Then of course, advance the Master level as needed.
May 13, 2011 | Peavey Electronics Peavey Pv8 6-input...
All the clip lights come on when connected to mains power
Power supply +15V and -15V failure, pay special attention to regulators.
Apr 08, 2011 | Peavey PV8 Mixer
PV6 clip lights stay on
You've lost one of the power supply rails. It needs to be repaired or replaced.
Jan 15, 2009 | Peavey 32fx USB 32 Channel Mixer
PV 1500 Amplifier
The final out put amp stage is out. MOSFET transistors likely. Hope this is helpful.
Jan 07, 2009 | Peavey Music
Peavey Electronics PEAVEy PEAVEy 8 CH USB MIXING BOARD PV8USB Logo
21 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Peavey Music Expert? Answer questions, earn points and help others
