Question about Ovens
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
My power was shut off, and after coming back on my Kenmore elite dual fuel Range/oven isn't heating. The display works, I can set the conv oven or regualr oven temp, and it will show "on" and clicking happens, but the temperature never rises (stays at 100 deg, then ultimately shuts off) Also, my ignition on the gas burners doesn't work unless the oven is turned on (even though it doesn't heat)
  • Travis Grant
    Travis Grant Oct 27, 2015
    We have the exact same problem. What was it? how did you fix it?? email me if you can please. tgrant1982@gmail.com
    Prodigy:
    An expert who has answered 500 questions.
  • Ovens Expert
  • 650 Answers
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Posted on Mar 02, 2014
  • 117 Answers
SOURCE: kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Posted on Feb 25, 2009
heatman101
  • 43501 Answers
SOURCE: Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Apr 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: Oven burner goes on on and off, Baking temp erratic
It appears your clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
ZJLimited
  • 17970 Answers
SOURCE: Kenmore Elite Gas range, model
Sound like the gas valve or the thermostat. In other cases, its more than likely your clock/oven control board thats bad; you would need a volt meter to check for 240 volts across your bake element terminals, where the electrical connections hook-up to it. If no 240 volts, then the problem is you electronic control board is bad as well.
Hope helps.
Posted on Dec 15, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Kenmore gas
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Dec 27, 2010
How do I override the sabbath feature on the elite dual fuel range?
since each model and each manufacturer operating procedures are different, it is best to read the instruction direct from your owners operating instruction booklet that came with the unit. If you don't have one, you can usually order one from sears parts direct for your specific model.
Sep 30, 2014 | Kenmore Elite Stainless Steel 40" Dual...
Kenmore oven take a long time to heat up, but bakes just fine once it reaches temperature. Is there anything I can do to speed up the heating process?
Start earlier?
>> check all elements for current,
check seals
check temperature calibration (allowed to be 15% ie 180 can be 153 or 207 Celsius!) no wonder Margs' scones cook faster at her house :-)
Oct 15, 2013 | Kenmore Elite Stainless Steel 40" Dual...
Kenmore Elite Gas Oven f1 message
Hi
Error code F1 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Kenmore Elite Stainless Steel 40" Dual...
Kenmore dual fuel oven model 79075503201. bottom element in oven will not heat. element has a resistance of about 22 ohms. 110v on each leg while off. 110v on each leg during bake cycle. I suspect the...
It seems that the control board is faulty. You would need to get the board repaired since it is no longer available for purchase from the manufacturer. You get the board fixed from www.partsimple.com at the lowest price compare to the rest of competitors online.
Here is the direct llink to the control board: http://www.partsimple.com/318010102-frg-r-12.html
Frigidaire Range Control Board Repair Service 318010102
Mar 15, 2011 | Kenmore Elite Stainless Steel 40" Dual...
My kenmore elite oven is giving me a F30 error message. what is this code?
Sorry to read about your problem, I hope this helps you out.
f 30 is a the oven temperature sensor open, thats the probe in the oven area
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Kenmore Elite Stainless Steel 40" Dual...
Kenmore Elite Gas range, model # 790.79363401 The range works but the oven does not seem to heat up. It appears to ignite, just not get hot.
the problem should be from the heating element of your Kenmore Elite Gas range. The heating element is either defective or may have loosed contact as a result of heat coming out of the Oven. The heat coming from the oven may have melted the wire connected to the heating element which might not make it heat up.
Disassemble the oven and check if its actually the wire connected to heating element that got melted, or its time to replace the heating element.
Good luck.
Dec 15, 2010 | Kenmore Ovens
Hi, my kenmore elite oven (#79075503207) has been on cleaning mode for the last 3 days, it is still making a noise and door locked. please help.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Dec 11, 2010 | Kenmore Elite Stainless Steel 40" Dual...
Have a Kenmore Elite oven. When I try to turn on any of the heating elements, I receive an F5 error. Any suggestions? Thanks much.
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Mar 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
254 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
