Question about Car Audio & Video
NOT START NOTHING 12VOLTIO HAVE AND REMOTE NOTHING KNOW HOW TO GET THE ELECTRIC DIAGRAM FOR REPAIR?
Hi ldv 05 convoy tipper wont start had it falt checked today came up with nothing as it turns over as it should but nothing thanks graham
you should checkout this website www.reliable-store.com that has books on all vehicles, name it they have it.
it covers wiring diagrams, electrical diagrams, fuse diagram, torque specs, PCV, error codes, fault codes, service info, repair info, parts info, owner's/service/repair/parts/maintenance manuals etc everything totally..
I have ford expedition and I keep servicing and when needed repair it on my own. worth it !!!
Mar 14, 2018 | Heavy Machinery
Although the red light for the TV is on and flicks when I press a chanel number on the remote, nothing happens-I have changed batteries in the remote. Any suggestions? TV is TX-L42E3B
At www.reliable-store.com get complete guide on whether to repair or not, service it, and how to repair etc, along with wiring diagrams, electrical diagrams, torque specs, error codes, everything.
Mar 13, 2018 | Televison & Video
Viper remote starter won't start the car even with a New key fob battery, it will crank for about one second then nothing.The car starts with the key and the door and trunk locks work with remote fob
You will get your solution and all info on service info, repair info, parts info, wiring/electrical/fuse diagrams, error/fault codes, torque specs, PCV,
it's a very good website for vehicle problems even as old as 1991 ford..
Feb 26, 2018 | Cars & Trucks
98 Bonneville does nothing nothing when I attempt to start it, however the lights,radio and alarms all work. I charged the battery. No change.
Testing the electrical circuit's would need to be done to find the problem . Looking at a wiring diagram for the starter electrical circuit ,to see what all is involved in starting the vehicle. First off is the security light lit on the insturment cluster ? Check engine light ? Do you know what a automotive electrical diagram is ? Here is a web site for free wiring diagrams . http://www.bbbind.com/free_tsb.html Enter your vehicle info. Year , make , model etc.... Then click engine under system ,then charging system under subsystem . Click the search button , then the second blue link . This is the starting system wiring . Looking at the diagram you will see there is a bunch of stuff . IGN switch , starter enable relay , park neutral safety switch ,Pass-key 2 theft deterrent module , starter . Knowing how it all works an where to test is the key to fixing a no start problem . Knowing computer controlled system helps too .
Electric Testing Techniques You Need to Know
Sep 10, 2017 | Cars & Trucks
Mr. Armor last year I turned my car off I want to start it back up and it did nothing no notice my lights everything came on but I flipped it over and nothing
It's very obvious you know nothing about the modern automobile and the electronics contained inside , do yourself a favor and take it to a qualified repair shop . Don't take this to hard , some people just are not meant to work on cars . If there were they would check out automotive electrical training , and how to read wiring diagrams . Plus they wouldn't be so cheap and buy a repair manual with wiring diagrams and test the electrical circuits . How to voltage drop test starter motor circuit Testing and not guessing is the proper way to do automotive repairs .
Dec 25, 2016 | Cars & Trucks
93 plymoth voyager, cranks but wont start replaced feul pump and filter,plugs and wires,coil pack,relays,fuse,and a sensor in the disrtibuter cap.nothing seems to work..what else could be the problem?
Before you replaced parts did you do testing of the electrical circuits in question ? Replacing all those parts you could had a qualified repair shop fix it already . Sorry but if you don't know how to do the testing you shouldn't be doing anything on your vehicle . Suggest you go on youtube watch video on basic automotive electrical trouble shooting , how to use a DVOM - digital volt ohm meter , how to read a wiring diagram . Also www.autoshop101.com electrical circuit basics . Electric Testing Techniques You Need to Know
Jul 20, 2016 | Cars & Trucks
Wiring diagram citroen xsara 2000
I see several different problems here.
First, installing aftermarket accessories like remote starts and alarm systems is asking for electrical problems with your vehicle. Those things are known to cause all kinds of problems including stalling, incorrect air/fuel ratio, and no-starts. Not to mention that the vehicle wiring harnesses usually get BUTCHERED in the process of installing them. They also make diagnosis of future problems (like stalling, no-starts, or computer fault codes) nearly impossible because the repair technician has no way of knowing if the aftermarket accessories are at fault or if it is being caused by a malfunction in the factory equipment.
Then, if you do not know where to start, it makes me question whether you should be messing with the electrical (and most likely, computer) circuits in your vehicle to begin with.
In addition to that, there is no way that anyone can help you to perform that task without having the instructions from the manufacturer of the system you are trying to install. Different systems tie in to different circuits in the vehicle. There is no way of knowing which vehicle circuits you are needing diagrams for. Did the system not come with instructions?
I have 2 recommendations for you:
1. Don't do it. If your vehicle is not equipped by the manufacturer with the options that you want, you are better off to save your money to buy a car that is.
2. If you choose to ignore recommendation number 1, I recommend that you seek the assistance of a qualified automotive repair technician in your area.
Mar 19, 2012 | Citroen Xsara Cars & Trucks
1998 gmc sierra wont start. battery is fine.
Did you try moving the gear selector to neutral ? Manual or automatic transmission ? Do you know what a wiring diagram is ? How to use a DVOM - digital volt ohm meter to test electrical circuit for the starter ? How to do voltage drop testing ? Where do you here the clicking ? Do you know what a starter relay is ?
Testing an not guessing is how to diagnose .
Starter Voltage Drop
http://www.bbbind.com/free_tsb.html Free wiring diagrams , enter vehicle info. year , make , model an engine size. Under system click on engine ,then under subsystem click on starting . Click the search button then the blue link . Testing the electrical circuit's is how to diagnose this , not guessing . If that is the best you can do you would be better off taking it to a qualified repair shop . This is how professional technician's diagnose .
Dec 21, 2017 | 1998 GMC Sierra
Key fob and the switches on dash do not lock or unlock door. found web answer that thinks the computer thinks the van has wrecks and keep the door unlocked so you can get out. the lights on the remote and...
You should go to www.reliable-store.com they have got books on every vehicle and also how to service/repair it,
service/repair/owner's/maintenance manual with
parts info, fuse box, gear box, torque specs,coiling, wiring diagrams, electrical diagrams, fuse diagrams, error codes, etc everything
Worth it
Feb 28, 2018 | 2002 Dodge Sprinter
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
