Question about Kenmore Ovens
Kenmore elite dual fuel range/oven model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unles
Kenmore elite dual fuel range/oven Model # 790.75503 (side oven and main oven - convection and regular - bake) 5 gas burners the displays work - oven doesn't heat and burners won't ignite without turning oven on (even if oven isn't working) - the power went off at my house, and after coming back on, this problem arose.
Master_Tech
  • 770 Answers
SOURCE: oven won't heat
do you see a bright glow in the oven area when the oven is turned on it will take 20 secs or so..If not your ignator maybe bad no gas will flow into the oven unless the ignt. is good
Posted on Mar 03, 2008
  • 22 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
jumptrout51
  • 3361 Answers
SOURCE: My Kenmore gas oven does not light.
Remove the oven Racks. Remove the oven base plate. Turn the oven on. You can then see the oven ignitor next to the oven burner. If the oven ignitor does not glow a bright orange,replace it. About a $90 part.
Posted on Oct 05, 2009
heatman101
  • 43501 Answers
SOURCE: Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Apr 07, 2010
SOURCE: top oven bake igniter comes on, but gas does not.
If the bake ignitor comes on (starts glowing) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. Faulty gas valve is uncommon, but still a small possibility. Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Posted on Jul 15, 2010
How do I override the sabbath feature on the elite dual fuel range?
since each model and each manufacturer operating procedures are different, it is best to read the instruction direct from your owners operating instruction booklet that came with the unit. If you don't have one, you can usually order one from sears parts direct for your specific model.
Sep 30, 2014 | Kenmore Elite Stainless Steel 40" Dual...
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
Kenmore oven take a long time to heat up, but bakes just fine once it reaches temperature. Is there anything I can do to speed up the heating process?
Start earlier?
>> check all elements for current,
check seals
check temperature calibration (allowed to be 15% ie 180 can be 153 or 207 Celsius!) no wonder Margs' scones cook faster at her house :-)
Oct 15, 2013 | Kenmore Elite Stainless Steel 40" Dual...
Kenmore dual fuel oven model 79075503201. bottom element in oven will not heat. element has a resistance of about 22 ohms. 110v on each leg while off. 110v on each leg during bake cycle. I suspect the...
It seems that the control board is faulty. You would need to get the board repaired since it is no longer available for purchase from the manufacturer. You get the board fixed from www.partsimple.com at the lowest price compare to the rest of competitors online.
Here is the direct llink to the control board: http://www.partsimple.com/318010102-frg-r-12.html
Frigidaire Range Control Board Repair Service 318010102
Mar 15, 2011 | Kenmore Elite Stainless Steel 40" Dual...
My kenmore elite oven is giving me a F30 error message. what is this code?
Sorry to read about your problem, I hope this helps you out.
f 30 is a the oven temperature sensor open, thats the probe in the oven area
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Kenmore Elite Stainless Steel 40" Dual...
Kenmore Elite Gas range, model # 790.79363401 The range works but the oven does not seem to heat up. It appears to ignite, just not get hot.
the problem should be from the heating element of your Kenmore Elite Gas range. The heating element is either defective or may have loosed contact as a result of heat coming out of the Oven. The heat coming from the oven may have melted the wire connected to the heating element which might not make it heat up.
Disassemble the oven and check if its actually the wire connected to heating element that got melted, or its time to replace the heating element.
Good luck.
Dec 15, 2010 | Kenmore Ovens
Hi, my kenmore elite oven (#79075503207) has been on cleaning mode for the last 3 days, it is still making a noise and door locked. please help.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Dec 11, 2010 | Kenmore Elite Stainless Steel 40" Dual...
Have a Kenmore Elite oven. When I try to turn on any of the heating elements, I receive an F5 error. Any suggestions? Thanks much.
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
