Home | HP | iPAQ H1940 Pocket PC | Problem wiht the fil...
HP iPAQ H1940 Pocket PC
Problem for HP iPAQ H1940 Pocket PC
Problem wiht the files browser
By cfam on Oct 26, 2007
It's impossible to open any file from my PDA.
impossible from any program or explorer.
when I click on the file name, it stand out in blue, but don't access to the file.
I did a soft reset but the problem didn't solve.
I did a Hard reset but the problem didn't solve.
Now I lost all my files, and the problem persists.
Comments:
Oct 26, 2007
- thank you very much Wormy 22
clarifying, i'm using the pocket pc file explorer, i haven't tried to explore with any other explorer program. The problem is also present when I try to open any file from the explorer of a specific program, for example pocket word or pocket adobe. Excuse my ignorance but I don't know what means "satarting fresh". If I conect with activ sync, it is possible to explore the files ffrom my pc, but i cant open any file in the PDA. Now i'm trying to update the BIOS.
Same Problem
Jan 02, 2009
-   I have the same problem: when I touch a file name, the file name is highlighted instead of opening the file, when I touch another file name, the file name is also highlighted (while the first file name is still highlighted)...I can't open any files. I'm still able to browse the file using my PC. It seems the file explorer of the PDA is not working properly. I tried soft re-set and hard re-set wtih no success.-   Guest
Nov 09, 2007
-   I have exactly the same problem.I've also trued by updating the Bios, but no way.
Gian
-   Guest
Best Solution
posted on Oct 26, 2007
Helpful)
wormy22
Rank: Wiz
Rating: 82%, 71 votes
Let's clarify a few things, when you try to access files on your PDA in file explorer or within a program it will not let you open it. I would try updating your bios and see what happens.  Here's a link to where you can get it.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=306679&prodTypeId=215348&prodSeriesId=322898&swLang=8&taskId=135&swEnvOID=1087
Also try browsing the files from your computer.  Also try starting fresh.  This is a really odd problem.  What programs do you use to try and open files?  Good luck with your issue.
Comments:
Oct 26, 2007
- Sorry, I meant starting fresh but I think that's what you meant by your hard reset.  If you hold down on a file to open the menu will it open the menu?  Can you browse through the folders in the PDA's file explorer?  Try putting a picture on the PDA through your PC and see if you can open it either through file explorer or the Ipaq's image viewer.  I hope updating the bios does the trick though.  I'm going to take a look at my Ipaq and see if I can't come up with any more ideas.
Was this helpful?
Yes
No
Popular Solutions for HP iPAQ H1940 Pocket PC
Questions and Unsolved Problems for HP iPAQ H1940 Pocket PC
Do you recommend HP iPAQ H1940 Pocket PC?
Answer
Answer
how do i transfer data from a usb flash drive onto my ipaq PDA. the ipaq PDA does not have a usb... (More)
Answer
My pocket cd is so ruined it cant run in my drive, so i cant install my drivers for the pda on the... (More)
Answer
My HP 3115 Is not loading when I turn on or resets, It show this screen that it says HP invert with... (More)
Answer
When I insert my battery the HP home screen is frozen with 1.07 showing. I can't proceed or do... (More)
Answer
My Hp ipaq h1940 pocket pc is frozen on the hp opening page with 2 1.07 at the top I have tried soft... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP iPAQ H1940 Pocket PC:
Top PDA Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
