Question about Sharp XL-MP60 Shelf System
Sharp xl-mp60 runs a few minutes, then goes into protect mode.
The cooling fan runs sometimes, but not continuously.
3 Suggested Answers
toolkits
  • 1099 Answers
SOURCE: XL-MP60 Shelf System: stereo shuts down and reads protect...
Hello, the problem of you stereo appliances been shut down was as result of a mechanism jam of the system.
The way you could do this is to open the back cover of the appliances and check for the rubber attached to the motor of the appliances, also check and see if you can adjust the mechanism if it is a disorder manner, it require a careful approach.
This will require a skilled personnel to handle this
Posted on May 19, 2010
walesarumi
  • 6993 Answers
SOURCE: how to remove the protect mode from sharp xl-mp60
The unit will go into protection mode when there is a short in the speaker wires or the unit was overloaded. Verify that none of the speaker wire connections are loose at the back of the unit or at each speaker. And verify that none of the wires are making contact with each other.
If it is, then remove the speaker wires and connect them again properly. After disconnection get the speaker wires, unplug the unit for 10 to 15 minutes or more. This will make the overload protection back to normal.
Try this and let me know what happens. I hope this would solve the issue
Thanks
Posted on Nov 03, 2011
My 2003 VW Jetta air conditioning is cooling for a few minutes and sometimes longer and then it stops cooling. The fan continues to run but the compressor apparently stops running.
Have you watched the compressor in action? The compressor is driven by the fanbelt which turns a pulley on the compressor shaft, but there's an electric clutch that disengages the pulley from the friction plate attached to the compressor shaft. You should hear a click when the clutch engages and disengages. Do you hear that? Can you see the friction plate turning with the pulley or does it stay in one position while the pulley turns? If if works for a bit then stops turning, you may have a damaged friction plate such that it doesn't engage with the pulley. Take your car to an auto A/C specialist and let them examine it. It's also possible that the relay that sends 12 volts to the clutch is intermittent and needs to be replaced.
Jul 22, 2015 | Heating & Cooling
Indoor fan will not stop
Seems like the fan relay has stuck (Likely to be on the main indoor PC board) or if the machine was being used on heating mode, the indoor pipe sensor may have failed causing the fan to continue to run. Most air cons on heating mode, will keep the fan running for a few minutes after you switch off on heating mode to cool down the indoor unit before it turns off completely. The pipe sensor signals the main PC board to tell it that the unit has cooled down and can now turn off completely. If either of the above faults occur, the indoor fan will keep running all the time.
Jun 19, 2014 | Goodman CKL36AR36 Air Conditioner
How to remove the protect mode from sharp xl-mp60 stereo
Thanks
Nov 03, 2011 | Sharp XL-MP60 Shelf System
May 17, 2010 | Sharp XL-MP60 Shelf System
AFTER A FEW MINUTES OF OPERATION ON MY SONY KF-42WE610TH LCD PROJECTION TV THE SCREEN GOES BLACK.THE SOUND COTINUES AS NORMAL.AFTER A COUPLE MINUTES IT COMES BACK ON THEN REPEATS UNTIL THE SET HAS RUN FOR...
First blush - the protective device called a "thermister" is heating up and "fusing". When the system cools down, the thermister releases the protection and allows the highvoltage transformer to provide power again.
Often times a device is drawing too much current - and the thermister shuts off the device to protect it - much like a fuse.
I have been able to maintain service on my TV by adding more cooling air to the existing fan. If your cooling fan is not turning fast enough - it can also cause the problem.
Nov 14, 2009 | Sony XL-2100U Projector Lamp for...
I have a Sharp XL-MP60. It powers up, shows a
Sometimes got fuses for the speakers check that but if they don´t got it the audio amplifier IC maybe are fried
Jun 11, 2009 | Sharp XL-MP60 Shelf System
My Sharp Room Air conditioner (Mod.AF-S120FX-A) when it's starts
Most likely the terrible noise you hear is the compressor starting... Sometimes it is louder than when its runs continuous. Just make sure if the unit is shut off allow a few minutes for the freon to equalize before restarting the unit. Its possible that the Compressor is going out, But as long as it cools and the noise goes away after a minute or so, i wouldn't worry about it to much.
Apr 29, 2009 | Sharp AF-S120FX Air Conditioner
Sharp 5 disc cd player
Email i got from Sharp:
I do apologize for the problems you are having with your audio unit. The protect mode
indicator will appear when the unit detects abnormal resistance in your speaker setup. I
recommend removing any additional speaker wire that may be added to the unit to extend the
factory speaker lengths. Also, make sure you have all the factory speakers attached, and all
non-factory speakers removed. Finally, please unplug you unit from he wall for 1 hour after
checking all of the above suggestions to completely reset your unit.
If you are still having issues after doing all of the steps mentioned above, the unit may need
to be evaluated by a Sharp Authorized repair center.
Oct 28, 2008 | Sharp XL-MP60 Shelf System
Protect mode
I own a Sharp DVD Micro System XL=DV60 that began to have a "protect" error message when I crank up the volume. Not sure if this applies to your system, but it could be worth a try. Before you proceed, the solution requires you to open up your system (Do not proceed if the unit is still under warranty :)).
IF you are not experienced in opening up electronic equipment, I suggest you find somebody who does. The error on my system was caused by the cooling fan being stuck or not able to spin. The system has a sensor or sense circuitry wherein, when it detects that the "amplifier" IC heats up, it spins up the fan to cool it down. IF the system detects that the fan is not spinning during the cooling phase, it will give out the "protect" message. Note that the fan only spins when you crank up the volume. Less or 0 volume will shut down the fan due to it's "energy star" feature. One possible reason why using headphones does not show the error, since headphones require less energy that the main speakers, thus the amplifier IC does not overheat. To solve the problem, I cleaned out the dust in the system via a 1 inch wide paint brush (haven't tried the compressed bottled air used to clean computers BUT it might do) and nudged the fan. Played the system w/o a cover and observed the fan operation and so far it has solved the issue. I plan to lubricate the fan shaft with very small amount(less than a drop) of machine oil using a syringe. If it does not work, I plan to see if I could purchase a replacement motor for the fan...
Again, I have not seen the internal layout of CD-BA2100 and not sure if there is a cooling fan. But then again, it's better than having the "protect" error popping up. :) hope this helps....
Oct 27, 2008 | Sharp CD-BA2100 CD Shelf System
XL-MP60 Micro Component System
Email answer I got from Sharp:
Nov 03, 2007 | Sharp XL-MP60 Shelf System
Sharp XL-MP60 Shelf System Logo
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
