Question about Bionaire BUL7933UM Ultrasonic Cool Mist Humidifier
How do I clean the transducer on my humidifier
I need to clean the transducer in my Ultrasonic Humidifier and no where in the directions tells how to clean it. Could someone please help me with this. Thanks
4 Suggested Answers
SOURCE: bionaire BCM630
Remove the water tank from the main unit. Now look down into the unit where the water tank sits. There is a small knob that you need to turn counter clockwise and the lower part of the unit incl the filter will slide out.
Posted on Dec 28, 2007
  • 123 Answers
SOURCE: White dust coming out of humidifier
A concern is minerals in the water. Impeller and ultrasonic designs send these minerals into the air. If the water in your area contains a lot of minerals, you will notice them as dust. The EPA does not issue health warnings about minerals in the air, but does recommend using low-mineral water (such as distilled water) in your humidifier. Many ultrasonic models feature a demineralization cartridge that filters minerals out of the water to prevent the dust.
Good Luck
Posted on Apr 21, 2008
  • 114 Answers
SOURCE: Instruction manual required for Bionaire BCM7305 Humidifier
http://dl.owneriq.net/4/4fe95eae-f9fb-4074-81ac-eb5ba1586517.pdf
here is the manual to help you get through on operating your unit. if you have any more questions please let me know.
Posted on Aug 21, 2009
Brand new. Why doesn't it work and won't mist?
if not working and is new, call your cust service for the humidifier and tell them, they will determined if u can fix or needs to be replaced, this is the only way
Humio Ultrasonic Cool Mist Humidifer Stylish Room Humidifier and Night...
Jan 05, 2016 | Humio Humidifier HU-1020 with Aroma...
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
Humidifier will produce mist for a min then stop If you look you can see it producing mist within but it will not come out of the top Walgreens cool mist ultrasonic humidifier
I have had times where my Crane humidifier won't produce mist if I haven't turned it on for several days (4+) or more. The water that sits in the reservoir may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
If your humidifier runs properly for a minute and then makes a whirring noise and goes silent (like the motor stopping), then it's a motor problem. The humidifier motor may have gone out of alignment due to bumping or rough handling of the humidifier when cleaning or emptying it. If that is the case, you will have to empty the humidifier reservoir, unscrew the base, and find the screws holding down the motor and check for misalignment. Loosen them a little and put it back together and try again.
Best of luck
thebqe
Feb 13, 2014 | Humidifiers
How do i use a challenge humidifier s35u-b
The challenge 3.5 ultrasonic humidifer is very similar to the Vicks one on the inside (same nubuliser etc.). It's manual is here http://www.kaz-europe.com/wp-content/uploads/VH5000E_OM_01JUN11.pdf and its made by www.kaz.com - they manufacture humidifiers under a few different brand names.
The vicks cleaning instructions are more stringent, I think because they are marketing this as a children's humidifier - they recommend bleaching the unit.
Mar 10, 2012 | Humidifiers
How do you clean the 705 ultrasonic humidifier
You can soak everything but the motor in bleach or vinegar water. Rinse well with HOT water.
The filter is disposable, cleaning doesn't help with them.
Nov 18, 2009 | Sunbeam Ultrasonic Humidifier
I need an online owners manual for AIR-O-SWISS 7135 Ultrasonic Humidifer. Thankyou
Here is the general download page for all AOS manuals and quick set-up guides.
Here is the direct link to the AOS 7135 manual in pdf format.
Oct 01, 2009 | Swiss AIR-O-SWISS Ultrasonic Humidifier -...
No mist, but i can see a water droplet fountain on the surface
if it's a cool mist unit it will not produce any mist. now if it's a warm mist unit it should. that's normal. it is possible to replace the transducer if it is damage but you are going to have some leakage from it. but the only way to get the transducer mainly is from the manufacturer
Mar 12, 2009 | Sunbeam Ultrasonic Humidifier
Not working correctly
Does your humidifier use an ultrasonic transducer for vaporizing the water?
May 08, 2017 | Crane Penguin 1 Gallon Humidifier
Sunbeam ultrasonic humidifier runs but produces no mist
It sounds very much like the transducer has failed. This is likely a crystal transducer and since they produce the agitation that should cause a mist, they are running continuously; not a good thing for something that is trying to shake iteslf apart all the time. These require input from a circuit that produces the fairly high level of power needed to drive the crystal so it could also be the source of the problem.
This isn't something an owner is able to diagnose unless they have some technical training.
Nov 08, 2008 | Sunbeam Ultrasonic 81696 Humidifier
Crane Adorable One Gallon Cool Mist Ultrasonic Humidifier
I posted the instructions for cleaning the unit a little while ago, but under a different Crane humidifier product. See http://www.fixya.com/support/t253969-cleaning_instructions
Nov 25, 2007 | Crane Penguin 1 Gallon Humidifier
Bionaire BUL7933UM Ultrasonic Cool Mist Humidifier Logo
Top Bionaire Humidifiers Experts
Vernon Taylor
Are you a Bionaire Humidifier Expert? Answer questions, earn points and help others
