Question about Pride Travel Pro 3-Wheel Mobility Scooter
Scooter batteries are completly discharged for a long time. the red light on. while connected to the 220v. All fuses are checked OK. the charger outlet is round 3 poles connector. you said it will not charge if it does not see some battery voltage? or maybe the new charger is also bugged? it seems wirry since the connections and charging scheem is quite strait forward. i wiil try and charge the batteries seperately outside. and see later if chsrging will start. or else somebody has different idea.regards Michael N.
  • Pride Master
  • 9,742 Answers
Use an automotive NON automatic style to charge the batteries individually. This may tale up to 72 hrs. to get the voltage up tp at least 10 volts. When that happens, the regular battery charger made for the scooter will finish off the charge. If the battery won't take a charge, then they're history.
Posted on Sep 03, 2017
SOURCE: scooter will not charge
sounds like the gell batterys you can try a battery conditioner it may charge them enough for your charger to work again .if the batterys are not charged or used for a wile the batterys will not let the charger work they should be charged almost all the time
Posted on Oct 11, 2008
  • 118 Answers
SOURCE: New batteries, fully charged, still wont work
I have the book if you can figure a way to post you email without getting too much SPAM. Be sure the charger is un-plugged, and that the free wheel lever is engaged.
Posted on Nov 27, 2008
  • 346 Answers
SOURCE: Hi. Our pride Ranger PMV
Hello Simon.Visit-www.alldatasheet.com its free.Download as a PDF File & save + if you choose print for future ref.To your Adobe Reader.Type in the correct boxes for a troubleshooter.Merry Xmas,any problem,please ask again,Colin.
Posted on Dec 16, 2010
  • 63 Answers
SOURCE: Pride Sundancer. Batteries will not charge. both
batterys may be to low for charger to pick them back up.Sounds like new batterys to me .dobble check that charger just in case by volt testing the neg and positive wires on one battery ,When its hooked up .then do the other to see if power is getting where its suppose to be. Your checking for volt changed .Battery charger checks out good replace batterys that should do it.
Hope I was of some help have a good day.
Posted on Jan 17, 2011
  • 692 Answers
SOURCE: I've just bought a second hand Jet 3 Power chair
on the Jet the charger light will come on only after it has charged the batteries if the light comes on green as soon as you plug it in then there is a problem in the charger circuit (loose connection or disconnected cable) also check your battery connections to make sure you don't have a loose connection or unplugged cable because that will cause the charger light to turn green as soon as you plug it in and you won't have power to the joystick. Hope this helps
Posted on Mar 01, 2011
How do I charge a moxie power scooter??
  • Turn the scooter's power switch to the OFF position.
  • Connect the charger's plug to the charging port on the scooter.
  • Plug the charger's power cable into a power outlet.
  • When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
  • Times recommended for your scooter.
  • Stop charging when the LED light is completely green.
  • Disconnect charger from the scooter, then from the power outlet.
  • Run your scooter before riding it to verify the battery charge.
Feb 02, 2016 | Health & Beauty
My gogo elite traveller wont chrage. The charging light isnt on when i plug the scooter in.
Sounds your batteries are to low in voltage for the charger to recognize. Also check the fuse on the battery box, normally a red one 10amps.
Feb 13, 2015 | Pride Mobility Products GoGo Elite...
Charger faulty, no charging.
hi, Sounds like a dodgy charger , check for a fuse on the side that the leads go to the scooter... I offer a free testing service, you only pay the return postage...UK only... One thing check the fuse in the battery pack, the charger will not work if it does not see the battery voltage
Regards
Rob
www.gewizrepairs.co.uk
Feb 04, 2014 | Pride Travel Pro 3-Wheel Mobility Scooter
Pride battery charger will not charge why?
There is a fuse in the charger. The batteries bay be too far discharged so the charger cannot recharge them. The batteries may be too old . Poor connections at the battery posts. Check all these and somewhere you'll find the problem.
Jan 07, 2013 | Pride Health & Beauty
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
The ammeter says its fully charged, but when driving the scooter the gauge goes into the red...is it the gauge, the ammeter, the batteries, or the charger?
I suspect this will be the batteries. The fact that the ammeter is working suggests the charger is charging the batteries. Just to be certain, the ammeter should start at a higher figure (i.e. 4 - 5 amps) the more discharged the batteries are, and should read zero when the batteries are fully charged. If this is the case, I think the charger and the ammeter are ok. The battery guage should also be ok as these do not usually move at all if they are broken. Batteries can take a, and even hold a charge for a certain period of time if they are weak, but under load, they cannot produce the desired amount of power. It sounds to me like this is your problem, but before you buy new batteries, have them checked properly as other things may be to blame, like a brake problem or even a motor or transaxle problem.
Sep 13, 2010 | Electric Mobility Mobility Electric Power...
The scooter is not taking the charge,the light stays yellow & red.
hi, first check the charger, can you try another charger ?
if you're convince the charger is charging ok then it points to the batteries being tired and need replacing but first check the connections to make sure there is not a loose connection.
Regards
GeWiz,
Jan 01, 2010 | Pride Mobility Revo 3 Wheel Electric...
Will not charge (It came with the scooter) it's charged time after time, but has failed. Charger will charge another scooter, but not mine. Shows red light only
then I would first chec kthe connections that the battery charger connects to, check the batteries on another scooter .
Regards
GeWiz
Aug 22, 2009 | Pride Mobility Legend 3 Wheel Electric...
Ezip 150 electric scooter. won't start.
Hi, did you charge the batteries for at least 8 hours? Make sure that your charger has a RED Light When you plug it in, You should see Green light in 4-8 hours depending on the Batteries.
Secondly Your scooter batteries were dead when you got the Scooter, Judging from the fact you didn't get a Charger with it. I would recommend getting a voltmeter and checking the battery voltages. If the voltage is 11-12 volts, then you need new batteries. If this doesn't work check that fuse on the scooter it could be blown.
Apr 15, 2009 | Electric Currie EZIP 500 Scooter
Scooter will not charge
Check the fuses may have a Blown fuse
Check to see if power supply witch charges the scooter is not faulty
Regards; Aaron
Sep 13, 2008 | Pride Sonic 3 Wheel Portable Scooter
Pride Travel Pro 3-Wheel Mobility Scooter Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
