Question about TP-LINK Computers & Internet
My cpu detetes the antena but says its a unreconice divice
Recovery lost pictures and videos at mistake detete
https://www.piriform.com/recuva
I hope they are on an SD card so that you can install the program on a computer and then insert the SD card in the computer and then run the program/
Nov 21, 2016 | Cameras
How to restore when laptop won't boot up
try changing boot divice at start up you hard drive may have falled
Jun 26, 2012 | Acer Mb.rjy02.001 Aspire 5250 Laptop...
OUR SYSTEM IS ITEL (R) PENTIUM (R) 4 CPU 2.66GHZ QUR BROTHER DELETED SOUND DIVICE SO PLS REQUISTED SEND ME ON SOUND DIVICE ON MAIL THANKS SANJAY
you will have to go the the manufacturers website of computer, (dell, hp, etc.) then enter the model number into their search and look for audio drivers. download the appropriate driver for your operating system and instal.
Jul 19, 2011 | Computers & Internet
When i installed Win XP SP2 on my computer (Main Board P5GPL-X) it'w not deteted with Network Controller and Video Controller Driver, How can i download it for installation? What is the best site for...
You need to go on the asus site from another computer and enter your motherboard model it will give you all the drivers you need to make all the components work correctly. Copy them on a USB key or burn them on a cd.
It will ask you for the CPU socket it is 775 for your board.
here is the link : Asus support link
Oct 29, 2010 | ASUS P5GPL-X Motherboard
Plz help me in my problem which r as under my
replace your CMOS battery, update the bios, then start over with the OS installation. verify a good OS install, then start back on the HDD partitioning.
Jan 02, 2010 | Foxconn WinFast K7S741MG Motherboard for...
Loosing GPS signal on a E120, also have 2-E80's on same boat, and they too loose signal
1. All your E Series MUST HAVE the same Software 5.23
2 You must set the Divice where the GPS Signal comes in as MASTER
all the other Repeater
3. Your GPS antena shoud be mounted outside
Sep 16, 2009 | Raymarine E120 GPS Receiver
Ess 1969 driver for vista
u on u r pc go to the control panel -> divice manager -> can u see the divices -> wts the divice yellow colur mark then u right clik the divice and select update option -> next option ->inset the pc drivers cd most and shut ->clik next -> serch the divice instal auto matic -> finesh. restart ur pc. can u call for me my no - 09177244290
Nov 22, 2008 | Microsoft Windows Vista Ultimate Edition
My hp photosmart 3300 can not be connect with divice
check whether its detected by the pc when you connect the usb wire to the pc and the printer.if not detecting then it could be the problem of the wire or usb drivers or the usb socket in your cpu is loose fit it tightly.
Oct 01, 2008 | HP Office Equipment & Supplies
LOW SIGNAL
Usually our CPU is on the floor or under the table, the common problem is signal, try to put your CPU on the table to roam a wider range. if still not much signal, just change your antenna with a better one.
May 20, 2008 | Linksys WMP300N Pre-802.11n Wireless...
Computers & Internet Logo
14 people viewed this question
Top TP-LINK Computers & Internet Experts
Martin Murray
alex metro
alex metro
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
