Question about Sony Audio Players & Recorders
Str-w770 stereo amp
Hi, I have a str-w770 amp and im find that on the right channel there's popping sounds & a slight humming. I fond that if i say change functions or if i reduce the volume from say level 1 to Level 0 (off) i get the popping. Have you seen this type of issue? Any ideas? thanks Joe
  • joe dimeglio
    joe dimeglio Feb 09, 2014
    just to add - have some basic electronics knowledge. I found the service manual and therefore the circuit diagram.
  • joe dimeglio
    So im happy to do some soldering but was really after any ideas or a logical approach. I found that there is a power supply board and one particular rail (-7.0v) seems to be grounded when i plug into the main amp board. The remaining rails look fine. Looking at the circuit theres a couple chips and capacitors. Have you seen capacitors short? Arent they support to burst their heads? All my capitors look fine?
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 161 Answers
It could be just a lead, check your lead heads and inserts are clean.
Check along your leads and wires for any obvious kinks / tight bends / cuts / nicks / something sitting down on it or any damage to the wires.
It could be just the dials / knobs need taking off and cleaning in behind. the pickups, you may not need to remove them just spray with electronic cleaner str-w770 stereo amp - b3203b06-4ced-4fda-befd-44f385f97b7e.jpg this stuff is great for lots of differnts electrical cleaning problems.
Good luck
Posted on Feb 09, 2014
petraman7
  • 1175 Answers
SOURCE: Gem Sound XP-350 both channels failed
Speaker fuses are generally fast-blow styles 250 volt glass
If an amp shuts down, with speakers connected, it sounds like one of the power supply lines does NOT like what it's "seeing" . Probably output transistors bad ( or module)
Take it to a tech.
Scott out.
Posted on Jan 08, 2008
  • 54 Answers
SOURCE: hafler dh220 power amplifier left channel distorsion
Sounds like your Power FET's are gone. Take it to a shop that specializes in high end or vintage gear. ....good luck...Rob
Posted on Mar 03, 2008
fixyathing
  • 341 Answers
SOURCE: Sound through one channel only.....NAD 310 Amplifier
If swapping of left and right input sources and left and right speakers does not help...you might have a bad channel in your amp.
Posted on Sep 25, 2008
SOURCE: Sugden a21a - intermittent loss of channel -
had exactly the same problem myself, changed the balance, and the selector until Sugden suggested the relay. this did the job, and my amp is sorted. Shouldv'e changed this in the first place. Good as new. Shaun
Posted on Oct 23, 2010
jerry1304
SOURCE: crate gtx 65 guitar amp mains hum
I had the same problem on my VTX65. I noticed it would oscillate with different effects so I removed the effects module. Problem solved. Now it's dead quiet. I use a Digitech RP500 so removing the effects module was a non issue.
Posted on Dec 27, 2012
2010 VW CC factory stereo amp popping sound
If the amplifier itself is making the popping sound I suggest you disconnect it immediately, as it could be an electrical short within the amp. If the popping sound is actually coming from the speakers, it could be due to a crossed wire, blown amp channel, or blown speaker. If you posses the technical know-how, you can test the amp channel and speaker by connecting a different speaker to the channel responsible for the popping sound. If the new speaker makes the same popping noise then it is most likely a blown channel. I hope this helps =)
Sep 24, 2013 | JVC AM FM CD DET FACE CAR STEREO
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
Apr 07, 2012 | Sony STR-DG800 Receiver
Sony STR-DE635, Sound from left surround speaker but not right
first turn the actual volume up on that channel on the reciver then make sure your speaker wires in the rear are using the same lenght each
May 18, 2009 | Sony STR-DE635 Receiver
The sound on my sony amplifier sounds too low inside the speaker.
Try getting the suround sound modes off and using straight stereo ,with no delays,or echos,
Jan 12, 2009 | Sony STR-DE595 5-Channel Amplifier
Sony STR-DE525 Left Rear channel not working
Most likely the amp for that channel is defective. If memory serves me correctly, there is a small amp chip mounted on the heatsink that is for both the left and right rear. I would change that first. It should have about 5-7 pins.
Dan
Nov 30, 2008 | Audio Players & Recorders
Sep 24, 2008 | NAD Audio Players & Recorders
Sony STR-DE595 Sound not balanced
HI...
It will need tech service.
Check the Sony consumer site for who can do it.
Aug 15, 2008 | Sony STR-DE595 5-Channel Amplifier
preamplifier or power amp internally but check your signal cables for shorts or breaks,if amp then is internal and needs to be serviced
Aug 13, 2008 | Sony STR-DE595 5-Channel Amplifier
No Center Sound
it probably isn`t :) it should be a problem with the settings :) i have a str de335 too and i get decent sound.. it depends on what type of source of input u`re using . try this.. hook up a stereo source. go into setup mode.. select wide or normal setting for center, then activate sound field .. c-studio for example.. if the sound is annoying something is wrong with the amp.. :-s btw use the delay settings from 1-6 6 if they are close together :) . When using 5.1 input... turn off soundfield always.. and triple check center settings&levels
Mar 22, 2007 | Sony STR-DE335 Receiver
50 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
