Question about Generic KEEBOX W150NR Wireless-N 150 Home Router
How i can create my password in my router ? - Generic KEEBOX W150NR Wireless-N 150 Home Router
  • 3,051 Answers
Hello there and welcome to fixya
It really depends on the make of the router for yours You set the password on the page you pull up in your browser (Internet Explorer, Firefox, Safari, etc) that controls the router; for many manufacturers this is IP address 192.168.1.1, it will most likely be under the "security" settings. You will need to select WEP or WPA settings (WPA is more secure) and if WEP, choose a 128 bit encryption rather than 64 bit. Keep in mind that the moment you save it, you will loose your connection until you add the password in the settings on your computer that control the adapter that receives the signal from the router. It is also advisable to make your SSID invisible to others; that way it will be more difficult for your system to be found and hacked.
Posted on Feb 09, 2014
Cannot Connect to router
You might reset the router then create a new password. Instructions on resetting, and defaults for the router are here:
http://pcsupport.about.com/od/d-link-default-passwords/a/dir-605l-default-password.htm
Aug 05, 2012 | Computers & Internet
How to create a password
Open your web browser and type 192.168.1.1 it will open router configuration wizard.
Enter in password tab and create your password so next time you open your connection it will prompt you for password you entered.
Jan 02, 2012 | D-Link DIR-615 Wireless Router
How can i create password in Wireless Router NetGear WGR614
to create a network security key or password for your router you need to access the 192.168.1.1 or www.routerlogin.net but be sure that you are connected hard wired to the router. after typing it, it would ask you for a username and password which is "admin" for username and "password" for password. it would take you now to the netgear page. on the left side of the screen you would see the wireless settings button. click on it. there you can start configuring the network name and password for your wireless. and just click apply settings.
Aug 31, 2011 | NetGear WGR614 Wireless Router
Says router password has been changed don't know password what do i do?
You can use the reset button on the back of the router and set up the router again like you did when first got it and create a new password.
Apr 20, 2011 | Linksys WRT160N Wireless Router
Forgot login password
Overview If you have forgotten your Linksys password, you have a couple of options. You can try to use the default settings to log into the router settings and change your password, or you can simply reset the router and set it up again. Either way, you will need to create a new password to use in the future. Read on to learn what to do about a lost Linksys router password.
Try the Default You can try to log in to the Linksys setup page and create a new router password using the default user name and password. This will only work if you did not change the default password when you originally set up your router.
Open a web browser window, such as Internet Explorer or Firefox. Type 192.168.1.1 into the address bar. Do not include any prefixes, such as http:// or www. Press Enter or click Go. A dialog box will open prompting you for a user name and password. Try leaving both fields blank and clicking OK. If this does not give you access, type admin into the User Name box and Password into the Password box. Click OK again. If you succeed, you can configure your router settings again and create a new password. Read the first article in this series, Configuring a Linksys Router Settings, to learn how to do so.
Reset the Router
If you are unable to log in to the Linksys router setup page using the default user name and password, you do have another option to solve your lost Linksys router password problem, which is to reset your router. 3d1cb9ca10deccfc3b6a854cda8b29a7cd240d6d_small.jpg
Look for a small Reset button on the back, front or the bottom of your Linksys router. The location of the button depends on the router model, so look carefully. As a precaution the buttons are small and inconspicuous, so that users do not accidentally reset their routers.
Once you have located the Reset button, press and hold it for at least ten seconds. You may need to use something with a small point, such as the end of a paperclip or a pencil tip to depress the button. Release the button and wait for the router to start back up. This will restore the router to its initial factory settings as it was when you first set it up. You will need to configure it again and choose a new password. Refer to the first article in this series for instructions on how to do so.
Mar 15, 2011 | Computers & Internet
How to set a password?
  • Access the router's default configuration address through your Web browser by entering this address: http://192.168.1.1 (see Resources). Do not enter a user name. Enter "admin" for the password. That process works for all new Linksys routers. If you have changed the user name or password in the past, use the user name and password that you created.
  • 2
    When the configuration screen opens, click on the "Wireless" tab and select "Wireless Security" to view the router's current security password. The "Security Mode" field will say "Disabled" if you do not have a password to secure your network.
  • 3
    Select the appropriate encryption type from the "Security Mode" drop-down menu. Linksys routers offer WEP and WPA encryption. WPA encryption allows you to use a single password to access the network. WEP encryption creates 10- or 26-character keys that act as your password. Some of your wireless devices may only utilize a certain type of encryption. Determine which protocol is best for your network.
  • 4
    Enter a password that will be required to access the network. For WPA encryption, you can write your own password. For WEP encryption, click the "Generate" button to create passwords that can be used to access the network. Write down your passwords and keep them in a secure location.
  • 5
    Click "Save Settings" to confirm your changes. Your network will now be secured and will require a password for access.
  • 6
    Click the "Administration" tab to create a password to access the router configuration page itself. Be sure to change the password from the default "admin." Reenter the password for confirmation in the next field. Click "Save Settings" to confirm your new password.
  • Feb 16, 2011 | Linksys Wireless-G WRT54G Router
    Trying to reset admin password on a Linksys E1000
    If you forgot Windows password, you can create a Windows password reset bootable CD/DVD or USB flash drive to reset your lost or forgotten Windows password, i have created a bootable CD with the tool Windows Password Breaker and reset my administrator password successfully.
    Dec 26, 2010 | Cisco Linksys E1000 WirelessN Broadband...
    Creat password for 3com router
    How to secure the wireless network
    You want to secure the wireless network.
    Is there any computer connected to the router with the Ethernet cable?
    If not then you will need to connect the computer to the router with the cable.
    Check the IP address on the computer. Open the router set up page.
    Once you open the set up page, you will find the option to make it secured
    May 03, 2010 | 3Com Computers & Internet
    Need to get wep key for new ps3 250 gig hard drive
    The wep key is for the wireless router. It is the password. If you enabled wep security on your wireless router and created a password, it is the password you created. If this is someone else's wireless network you will not know what their password is.
    Mar 14, 2010 | Sony Playstation 3 (PS3) Console
    How do I secure my router
    For securing your router do the follwing:
    1. Change your admin password on your router (you must setup a difficult password ... something like Admin015^^#2X)
    2. Create Wireless Password using WPA or WPA 2 tehnology and setup a strong password.
    3. Activate firewall on our router.
    Mar 05, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Generic KEEBOX W150NR Wireless-N 150 Home Router Logo
    91 people viewed this question
    Top Generic Computers & Internet Experts
    D. E. Hev
    Steve
    Are you a Generic Computer and Internet Expert? Answer questions, earn points and help others
