Question about Apple iMac Computers & Internet
Hi. My iMac is frozen on the grey screen with the apple icon and logon logos. The mouse moves but I can't get past the is screen. I have tried the suggestion listed below including doing a hard shutdown (by holding the power button for ~ 10 seconds) and then attempting a PRAM reset by holding down the Command, Option, P & R Keys simultaneously but it is still get stuck on the above screen when restarted. Also, tried to reboot on Safe Mode by rebooting the iMAC with the Shift Key pressed down and finally I arrived back at the above screen with a "safe boot" in red at the top of the screen but still the screen is locked and I cannot get passed this screen. ( i.e. I cannot get any Finder menu to open to open up any folders as you suggested. Also, your #2 suggestion of trying SMC reset is not possible since I'm always frozen on the above screen. Any other suggestions would be appreciated. Otherwise, I guess I'll just have to bring the iMac back into the apple store to get it fixed. Thanks for any other input.
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 161 Answers
If its under warranty just take it into the store or
Try this,
Unplug it from the wall, (Remove the lead from the plug in the wall) unplug it from the computer, Isolate the PC from the power supply.
Wait a while before you open up the back of the computer to make sure all the capacitors are fully discharged and use a Anti-static wrist strap used to protect computer electronics
When a person handles computer boards, it doesn't take much of a spark to damage the circuitry. Anti-static wrist strap used to protect computer electronics.
Hi. My iMac is frozen on the grey screen with the  - 4ba492d4-3068-43f4-90b5-7ed979cf4eb5.jpg
Now reset your cards and other components. when you do this make sure you seat them back in correctly.
Take the small battery out of the motherboard, wait a moment and put it back in.
Hope this was of some help
Posted on Feb 09, 2014
damien729
  • 221 Answers
SOURCE: My iMac G5 1.8 GHz 2GB ram computer desktop
Hello
If you can run it in safe mode, that means that you have an extension problem. I had most of the time problems with the ATI extensions.
First of all try too boot on another account, an new one would be good, to check if this is not account related.
Secondly i would reinstall the system (a clean install would be good, tough you can try an archive-install)
Thirdly if it isnt fixed I would delete all ATI extensions instead of the one that your graphic card uses. to delete: go to /System/Library/Extensions .
Hope that helps
Posted on Aug 06, 2009
  • 1099 Answers
SOURCE: when my imac g4 tries to bootup it shows a folder icon
It sounds like the system is corrupted. What I would do is to get your instal disk and boot up holding down the c key on your keyboard. Once you have booted up go to the file menu and run disk utility to verify and repair the hard drive. Then go to the instal menu and instal a fresh system remembering to preserve the users data so you do not wipe anything. Hopefully this will work.
Posted on Oct 13, 2009
Macs R We
  • 481 Answers
SOURCE: imac periodically freezes. No recourse but to shut
This behavior is usually symptomatic of an internal drive that is failing or has failed. The pinwheel appears when the drive is unable to deliver a certain block that the CPU needs to proceed. In our shop, we would boot from a Drive Genius CD and run the Scan test on every block on the internal drive. If blocks show up as bad, the best course is to replace the drive. If no blocks show up as bad, we would run DiskWarrior on the file system to clear up any volume inconsistencies, which can also give rise to this symptom. If neither of these solves the problem, we could back up the user files to an external drive, reformat the internal drive using "erase writing zeroes," reinstall the system from scratch, then replace the user files.
Posted on Nov 28, 2009
  • 739 Answers
SOURCE: can't reboot iMac and disc is stuck in the slot loading drive
Shut down the mac by holding in the power button for about 10 seconds.
Is the CD a system CD or something else?
If it's a system CD restart the mac and hold down the letter C on the keyboard. after about 30 seconds the mac should boot up into installation mode. If it does, click on the language then then at the next page go up to the menu bar and locate Utilities and disk utility. Run the disk repair then try and restart. (The flashing ? means that the computer cannot find a start-up drive with a valid system on it. The repair routine can sometimes fix that - it doesn't always though.)
If it's not a system CD and you obviously need to get it out before you can do anything else - restart the mac but this time instead of holding down the C key, hold down the click on the mouse. It takes 10 to 15 seconds (sometimes longer) but it will force the computer to eject t the CD.
Posted on Feb 14, 2010
  • 1619 Answers
SOURCE: iMac will not power on.
Power supply would be the best bet.
Posted on Apr 13, 2010
How do I bypass my password on my IMAC computer
hi Gabrielle.
try this.
Press the Command and R keys at the same time when the grey screen appears and hold them until you see the Apple logo. A small loading bar will appear under the logo. Sit tight as your system boots into Recovery Mode. Click the Utilities tab in the top menu bar, select Terminal, type reset password and press Enter.
if this does not work go to this link and it should help you out some more.
How to bypass password on IMAC computer Google Search
or this one.
Bypass and reset the password on any Mac in no time
or this.
Five Ways to Reset Lost Administrator Password
or this.
Dec 03, 2017 | The Computers & Internet
Computer starts up to grey screen and apple logo then shuts down.
The machine worked perfectly for years and now it is failing. That may be just Hardware wear. The owner should be grateful for such good luck.I would try to reinstall the old OS version and see if the problem disappears. But I doubt it. If the problem persists then the OS upgrade is not responsible for it. Maybe a cleaning of the vents will do. If heat is not evacuated, the fan has to work harder. With age it is no longer able to handle the load.
Jan 19, 2014 | Apple Imac 20" Desktop august, 2007 -...
Imac intel blue screen
Can you start up in Single User Mode? Restart and hold down the command/Apple & the "S" key.
Apr 17, 2012 | Apple iMac G5 Desktop
Imac os intel core 2 duo inverter
Pop in your OS X DVD and run a repair install or an archive and install.
Imac screen moves around with cursor
Is your screen image also magnified?
It sounds like you accidentally zoomed the screen, which you can do by holding down the control key at the same time you are rolling the wheel on the mouse. When you do that, the screen will follow your mouse so that you can access portions of the screen that have "zoomed off."
Hold down the control key and roll the mouse wheel until you have zoomed all the way back in. Alternatively, visit System Preferences / Universal Access and modify the Zoom options to suit yourself.
Mar 02, 2010 | Apple iMac G4 Desktop
APPLE IMAC G4 - TRYING TO INSTALL OS WITHOUT DISK EJECT BUTTON
Reastart the iMac and at the same time hold down the mouse left click button. If that does not work.
  1. Restart the computer.
  2. Immediately after the startup sound, press and hold the key combination Command-Option-O-F.
    Note: The Command key has the Apple and (commandkeysymbol.gif) icons on it.
  3. Release the keys when you see a white screen that says "Welcome to Open Firmware."
  4. At the prompt, type: eject cd
  5. Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the action is complete.
  6. Type: mac-boot
  7. Press Return.
Dec 11, 2009 | Apple iMac G4 Desktop
The startup window on my iMac 2006 Intel dual core stays on. The spinning circle just keeps going. I can't get past this point.
this seems to be a issue with the internal hard drive if it does not pass the logo screen, You might need to have this repaired, call you local apple store make a appointment to bring in your imac. sounds like a hard drive corash correct me if i am wroung I been working on macs for 5 years not to long huh? But I am knowledgeable is why you see the apple icon next to my name. Have the hard drive checked you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 02, 2009 | Apple iMac 24" Desktop
The computer comes on but is frozen on Apple screen
I would try pressing f2 or f8 when first boots up, then change bios settings from first bootup device as cd rom drive, then hard disc as second drive, then place windows disc or recovery disc in pc, then reboot. and reinstall your software.
Oct 01, 2009 | Apple iMac G5 Desktop
Computers & Internet Logo
43 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
