Question about York Fitness Z16 Treadmill
Board broken running board is cracked
My OS-2 Distortion pedal will not work. There is current flowing to the battery terminal, there is also contact noise in the output, but none in the input. The red light does not come on when powered and...
Common problem is a broken solder connection where power jack is attached to the circuit board. SOmetimes the circuit board is cracked or solder broken. If board is cracked, jumpers need to be soldlered on to bridge the crack.
May 07, 2011 | Roland Boss OS-2 Overdrive / Distortion...
My sandisk cruzer 8gb was stepped on while in my xbox 360 and i wont light up nor come on when i hook it up to my computer how do i fix it
You could crack it open and resolder all the broken connections in it.. but.. your better off buying a new one. their a pita to repair.
Apr 11, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Panasonic LCD TV with cracked screen
Sorry,not repairable,because the LCD,PLasma,and DLP screen are limited produced.Replacing the tv pannel screen will cost the same as a new tv.Might even cost more after the labors.The tvs screen is about 90% of the tv,that why when is broken or damage,now it only use for it electronics boards parts,or sell for it electronics boards parts that it.
Mar 15, 2010 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
The circuit board has cracked, and a lead on a transistor marked C546 has broken. Where can I get a new transistor, or is there amodern alternative from Maplin?
I doubt if you will be able to obtain the correct part, unless the transistor has the values marked on it, and if the board is cracked, then you will will have to make sure that the tracks are not broken, and there is continuity through the revelent circuit.
Mar 12, 2010 | Hotpoint Ultima WD72 Front Load...
Dropped sony tv trinitron face down, ti goes to standby
You have a cracked board inside the TV. The biggest weight creating the crack would probably be the Flyback transformer. And you may have done damage to the tube internally..the shadow mask perhaps? The yoke or the neck of the tube is broken.....Could be a lot of things or minor...just have to check with a tech!
Nov 23, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Not switching on (cracking and poping)stand by light flashing on and off
The capacitors on the power board or one of the Sustain boards have broken down. This can lead to fire if yoiu persist in trying to run it. I suggest you get professional in to rectify this as it is not a DIY. The more you tried to run it the worse it will be and now it may involve more than the few components that blew originally.
Please rate our help++++=Thanks for using FIXYA
Oct 08, 2009 | Samsung Televison & Video
Broken and cracked 42' sanyo lcd tv, the screen is all yellow, orange and can see all of the cracks throughout the tv, can it be fixed and how much if possible?
Unfortunately it is not, The cost of the screen is just as much if not more than a new tv. Sorry to be the bearer of bad news, but in our shop we have seen may sets broken with the WII and it is a very sad day for our customers. Warranty will not replace a cracked or broken screen.
There might be a small silver lining to this though, the boards in your tv are valuable for repair purposes. It is possible that you could sell the boards through e-bay to make up some of the loss, but you must list the correct part number. That is how people will search for boards, we have done this before and we have purchased boards for brands we normally don't work on.
Oct 07, 2009 | Sanyo 42 in. LCD TV
Mxr phase 90 block logo and the 9v power jack not working
These break and SOMETIMES the circuit board gets cracked.
Open up and inspect for damage. If board is cracked, bridge broken traces by soldering wires around the break.
If the solder is broken, resolder it.
If the connector is damaged or weak spring, replace the connector.
Sep 12, 2009 | MXR Phase 90 Pedal
Have power, but no picture.
by power due you mean sound? remove back ck if any cracks in pc board. or crt broken? discription of prob vague. if board cracked or crt broken not worth repair.
Dec 03, 2008 | Toshiba 32AF43 32" TV
Cracked circuit board
Try partstore.com, they have an "A" board (p/n A-1299-243-A) for this model for about $170.
Other than that it is pretty strait forward to jumper across the crack with a little wire on every broken trace. Look close, don't let all the white lettering on the PCB fool you.
Done this many times, rarely any component failures.
Dec 31, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
York Fitness Z16 Treadmill Logo
26 people viewed this question
Top York Fitness Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a York Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
