Satellite manuals How do I change touch screen to mouse
Hi guys !my computer ls a Toshiba satellite L840.everything was Alright and just like that The computer's mouse didn't work. I can't do anything.
You did not post what operating system you have. But you need to boot to safe mode and see if the mouse still works. If you are using windows with touch screen you can touch the area near the clock and get to the touch pad symbol and make sure it is enabled. The other thing you can do is use another mouse to get to the diagnostics or the device manager to check for issues.
Jun 26, 2015 | Toshiba Computers & Internet
No mouse control via wireless mouse, or touch pad
IT SOUNDS LIKE YOU HAVE MAY HAVE DRIVERS OR IRQ THAT ARE CONFLICTING, TRY UNINSTALLING THE DRIVERS FOR YOUR WIRELESS MOUSE, AND REINSTALLING THEM, MAKE SURE THE WIRELESS MOUSE IS UNHOOKED BEFORE YOU REINSTALL THE DRIVERS.
Mar 11, 2010 | Toshiba Satellite Pro L300 Notebook
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
I have model A355-S6935 its a new unit. My problem is when typing the type skips out of the sentence into the lines already typed. Is this a common problem as it causes major rework and is extremely...
easy, your touching your mouse pad (square you touch to move the mouse), you can turn it off and use a regular mouse, turn off the laptop, plug in a mouse, windows will automatically detect it.
On every Toshiba notebook Touch Pad can be disabled on two different ways. The first one is using FN+F9 key combination or using DISABLE option in mouse properties.
Make changes to the mouse and mouse pointers in the Mouse Control Panel. To open Mouse, click Start, click Control Panel, click Printers and Other Hardware, and then click Mouse.
Good luck,
Mr.Fix-it-guy
Aug 13, 2009 | Toshiba Satellite A355-S6935 Laptop
Toshiba satellite 25505 screen resizing
Toshiba Laptop Mouse-pad Screen Resizing is annoying. Here is the solution. Go to: Control Panel < Mouse < Device Settings <Settings (middle of page right box) open it and look at menu on left top and select Pinch Zoom and disable it. The pinch zoom re-sizes the window bigger or smaller . This is what happens when you have you left finger on the mouse-pad while scrolling with you right, its doing the same thing as re-sizing the image like one does on a i phone using index finger and thumb.
Aug 04, 2009 | Toshiba Satellite A100-S8111TD Notebook
Frozen mouse with a touch pad laptop computer
My laptop has the mouse pad built in and it froze up..I cant do a thing .I have tried to shut down and if you dont have a mouse working you cant even go to task manager etc..Now what? It is new I have only had it a month...
Dec 29, 2008 | Toshiba Satellite L305D-S5895 Notebook
Toshiba satellite 1805 windows xp touchpad does not respond to one or two clicks although it does move the arrow around
Go into your controll pannel then click on mouse. On the mouse properties click on Touch Pad, then you can change the settings for sensitivity of the touch for double clicking with the touch pad.
Apr 28, 2008 | Computers & Internet
Maximizes & minimizes screen while scrolling or using pointer on Vista
change mouse out buy replacemnt goes under the plastic housing not to bad to change 20 bucks on ebay
Feb 02, 2008 | Toshiba Satellite A135-S2276 Notebook
29 people viewed this question
 Grubhead
Grubhead
