Question about Panasonic Televison & Video
Panasonic er205 BLOCK SPRING NEEDS FIXING. HOW DO I FIX IT?
How can i reprogram the panasonic vk925d?
Where can I fix my panasonic 5 disc changer......the shuttle is no longer working....plz help am at Mpumalanga
Jun 24, 2014 | Panasonic Audio Players & Recorders
Husky power washer 2600 Tried fixing starter
I'll send you a link to a great video of how to recoil a starter spring, so you wont lose and fingers or eyes. :)
Aug 01, 2013 | Garden
How do i mount my panasonic tx-l26x10b on the wall. no fixing holes
drill holes put in wall plugs fix bracket insert and tighten screws
Aug 07, 2012 | Panasonic Televison & Video
Our panasonic inverter microwave (3 years old) needs repeated hard slams to shut the door so that the light goes off and the microwave will work. How do we fix this problem as I'm afraid we are going to...
We have a Panasonic Inverter microwave. Door became difficult to close and had to slam it hard while holding themicrowave to keep it from moving. When opening the door did not pop open but did unlatch. I ordered a new door lever from Panasonic. When got part I removed case from microwave and lever was okay. I then removed the perimeter strip on the inside of the door. With a screwdriver I stretched the spring at the bottom that keeps the door latches pulled downward. Spring still worked just not as stiff. Put perimeter piece back on the door and replaced housing (which I didn't need to remove in the first place), and then put a small drop of vegetable oil on the cams where the door latches hit when closing door. Viola, door opens and closed as new. Problem solved. Diagnosis: over time the latch tension spring hardens and gets too stiff. P.S.: I had several similar springs as backup in case I screwed up the original one.
Jan 16, 2011 | Panasonic NN-SN657SMicrowave Oven
97 Saturn passenger side front door
sounds like the spring has gone bad.the spring pulls it open when you pull the handel.or has come un done. if the spring is gone it should move freely.if not some grease should do
Jul 27, 2009 | 2005 Infiniti G35
Lens failure or lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Aug 21, 2008 | Nikon Coolpix 8700 Digital Camera
Panasonic projection
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Nov 13, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Error Message H07 - what is it?
The last time I opened up my Panasonic DVD-CV52, I looked at the little white bush on the motor spindle, it has a small spring which presses against the side of the bush. I can see no purpose for this spring/bush other than to provide some drag to the motor. Anyway, I removed the spring, so that the bush would no longer drag against the shaft, that was a few years back, and I haven't had a problem since. Of course a temporary solution is to oil the bush!
The www.ledcar.com/pdvdh07/ link mentioned above provides an excellent pictorial guide to disassemble and reassemble the player.
Jun 09, 2006 | Panasonic DVD-CV52 DVD Player
Televison & Video Logo
22 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
