Copiers
Problem for Copiers
Generic problem for all Copiers
Sharp AR-207
By geevus on Oct 26, 2007
On Wed. I used the machine and it seemed just fine.  I turned it off and left it off all night then on Thursday morning I powered it up, it came on and went through it's warm up routine?, and then it powered itself down and will not power back on.  I have changed the power source to no avail even though the two (2) other items plugged into the surge protector never stopped working or lost power.  Is there some kind of fuse that may have blown in the machine or perhaps a reset button?
Comments:
Oct 27, 2007
- I will check the fuses, thanks!
Best Solution
posted on Oct 27, 2007
Very Helpful)
copier guy
Rank: Wiz
Rating: 91%, 42 votes
sounds to me that the power supply has blown, or fuse onthe power supply. If you remove the left side cover you will see the power supply. Please unplug the machine first. check fuses if they are good, the power supply is bad.Let me know if you need more help.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
conica minolta bizhub 35o vs kyocera in same price range
Answer
I have rizo 220 wich cannot pull a muaster roll
Answer
hello. i have a client that have a irc1021i and have the windows xp home edition . can the machine... (More)
Answer
CLX-2160N we are getting a yellow strip down the right hand side of some pages. Its not all the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Copiers:
Top Copier Experts
Rank: Guru Guru
Solutions: 761
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
