Question about Radio Shack Pro-97 Handheld Scanner
Nascar pro-84 200 channel racing scanner was dropped and volume and squelch no longer work
Our nascar scanner was dropped volume no longer works what do we do
SOURCE: NO SQUELCH
I have a Radio Shack Pro 97 Scanner that I received as a present 1-1/2 years ago. It was working just fine and then suddenly there was no squelch or volume. The keys make noise when pushed, but there is no sound for the squelch or volume. The scanner scans the frequencies but does not stop and play. I went on line and found that other people were having the same problems. I went back to the store that the unit was purchased from and received no help what so ever, they said it’ s off warranty and I was out of luck, nice way to do business??. I think that something that cost as much as this should not be junk after a short period of time. I hope you can help me with this problem I do like radio shack, but I can’t afford to buy items that don’t stand up.
Sincerely
Greg Stevens
e-mail
fooyun@sbcglobal.net
Posted on Aug 28, 2008
  • 8 Answers
SOURCE: squelch quit working in regular scan mode PRO-528
Just fixed my squelch problem; I don't know how it happened but Resistor 138 was burned & intermittant. It was so badly burned that I could not read the color code but it measured 880 ohms intermittantly. I replaced it with an 860 ohm carbon resistor & all seems well; time will tell. R-138 is located on the circuit board right behind the squelch potentiometer. R-139 is immediately behind the pot & R-138 is next to R-139. All I had to do is remove the 4 screws on the back of the case & the unit splits in half. I clipped the old resistor out leaving a bit of the old leads so I could solder in the new resistor without having to get to the backside of the circuit board. Scanner is working as I type this & I hope it does not burn out again. Hopefully this is the same problem in your scanner & an easy fix. Good luck.
Bob Tomlin
WB1AIJ
Posted on Dec 22, 2008
radiorob1
  • 17 Answers
SOURCE: Radio Shack PRO-49 handheld scanner. Turns on,
The "hot" pin inside the BNC antenna connector is probably broken or disconnected internally.
Posted on Oct 10, 2009
  • 5603 Answers
SOURCE: I HAVE A RADIO SHACK PRO 97 SCANNER WAS WORKING
Check if one of the batteries MIGHT be in backwards.
NEXT check EACH cell as occassionally you get a bad one brand new.
Posted on Nov 14, 2009
BillB-SA
  • 2761 Answers
SOURCE: looking for a part number for a
Here's a link to the parts list for your scanner. Parts can be ordered online or from your local Rat Shack store.
http://www.icomamerica.com/en/support/PartsAndService/default.aspx
Posted on Dec 20, 2009
Last night was working fine - as it was on I noticed that the scanner was just stuck on one channel - I hit scan ( I have several channels programmed) It wouldnt scan. Then when I turned the squelch...
Hopefully Resetting or Initializing the scanner will clear the problem and get it working again for you. Instructions for these procedures are on page 38 and 39 of the scanner operating manual. If you don't have the manual, you can download and print it, at no cost, here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
Bill B.
Listening in since the 60's
May 24, 2011 | Radio Shack Pro-82 Scanner
I have a pro 84 race scanner that I am trying to program for the 3 nascar race series. Since this scanner does not have a button to program the car # I am somewhat lost. It was suggested to use the car #'s...
Sorry, but the NASCAR label on these scanners is little more than a scam. There are no special features that make race scanning easier or organized -- they just cover the frequency range that cars and pit crews operate on.
Bill B.
Listening in professionally since the 60's
Mar 10, 2011 | Radio Shack Pro-84 Handheld Scanner
SCANS BUT WILL NOT ICK ANY CHANNELS AND HAS NO
Turn the scanner on and volume up all the way, turn the squelch until you hear static, then turn the squelch down slowly until its silent, press scan, has it ever been programed? Just a thought. hope this helps..
Mar 25, 2010 | Radio Shack Pro-94 Scanner
Volume problem
With volume turned up, turn the squelch till silent, push scan, ..hope this helps..........
Feb 16, 2010 | Radio Communications
NO SQUELCH
Sincerely
Greg Stevens
e-mail
Aug 07, 2008 | Radio Shack Pro-97 Handheld Scanner
My pro-2018 won't scan anymore.
you may need to re program it and get a external antenna.i recommend that you get a scanner pc programming kit.
Jan 31, 2008 | Radio Shack Pro-2018 Scanner
Squelch is open all the time
Often the potentometer (squelch control) becomes worn or dirty, this can be sometimes cured by spraying a WD40 or similar oil and then rapidly moving the control down and up. Do not use oil that is conductive.
Sep 11, 2007 | Radio Shack Pro-2096 Base Scanner
Radio Shack Pro-97 Handheld Scanner Logo
32 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
